SOURCE: I've read many posts regarding
If your tv works fine in viewing movies in dvd or cable there is no problem with the tv. Your right about the compatibility issue you must manually change the graphic format of your computer but if your tv has an HDMI output try to connect your pc in that input. Hope this may help good day and best regards.
The driver is needed if the correct resolution for the monitor is not on the listed, it will not affect the sceen symptom that you are having. Color casting (Red, green, blue, pink, yellow, etc. color casting the whole screen) on the screen is usually caused by poor video cable connections or bent pins or bad PC's video card. I would check that first. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
This monitor is known for bad caps for sure, and it can cause a lot of starnge problem.
We need to find out first if it is the monitor or the PC problem. You will not find win7 driver for this monitor since the company no longer support this old monitor.
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
