SOURCE: file errors
http://www.samsungcamera.com/popup/download.asp?prj_uid=741&prol_uid=4153
Download the english manual version pdf file and open with adobe reader go to page 84.
When you upload a file that is not taken by this camera to the removable disk, the [File Error!] message will be displayed on the LCD monitor in the play mode, and nothing is displayed in the THUMBNAIL mode.
Make sure that the memory card is formated in the camera not the memory card reader on the computer. Make sure you save your edited files in jpeg file format. Avi for movies. The manual makes it sound like the camera will not read altered files or files not taken by the camera itself. edited files are not files taken by the camera. Good luck I hope this helps.
Please rate me.
SOURCE: pics turn white with lines when taken outside in day light
Check to see if your ISO is set to a high number like 800 or 1600. If so, set it lower or on auto ISO. Your white balance should probably be on auto white balance. Go into the setup menu and see if your camera has a setting for "reset". This could take your camera back to factory defaults.
SOURCE: problems with the samsung camera. the screen is blank black!
Sounds like the ZIF connector for the screen or another part came loose. I will say it sounds like a hardware issues and I would strongly recommend looking into coverage via manufactures parts and repair coverage. About the picture folder not showing up, If your using the camera cord to attach it to the computer Make sure you turn the camera on after connecting, if the drive for the camera does not appeare in " Computer " I would say get a card reader for the SDHC cards and try to load the pictures through there.
SOURCE: hi, I'm having some problems with my samsung
This is happening due to your wrong settings..
So first you rest your camera to factory defaults... and confirmed that night mode is off for daylight picture...
Take photo on Auto mode... and see the result.... If still not satisfied then camera get serviced...
SOURCE: SAMSUNG S1070 - When I
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
