Please make sure that the discs do not have scratches . Then, you can clean any lens that the jvc machine uses to read your disc. Afterwards, you can attempt to play the discs again.
If this does not work, please factory reset your device before attempting again. Otherwise, I think you might need to have the device repaired or potentially replaced.
Please go here and download the live update from Samsung. This software is designed to automatically update you to the latest firmware via the internet. To get this service, customers have to install the Firmware LiveUpdate program on their computers.
Updated firmware last night (for the Bd370) and the main movie disc for Chronicles of Narnia: Lion,witch,wardrobe worked (after previously stalling). However, the bonus disc still doesn't work when I play it (just a blank screen). I traded the Blue-ray DVD from where I bought it for another one, and it made no difference. However, both Narnia discs played okay in the store on a Sharp blue-ray DVD/Tv combo.
i don't think it's a firmware update. if it's out of warranty, open the device and clean the leans. clean them with something smooth. after that put all together and pray it will work. if not you'll have to buy a new one
You may be using the wrong type of DVD format. Some DVD-ROMs and players will only read certain discs. i.e. DVD+R, DVD-R, DVD-RAM. If you are trying to read a DVD-R disc that was bought blank, and then had things burned to it, it may be that the disc wasn't finalised after burning. You could always try updating the Firmware version by downloading it from the website.
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
1.Please cheack weather the DVD meadia is DVD R/W combo drive,
2.Then only the DVD media will be Burn or write tO the Blank dvd media & then check weather the blank cd is a dvd r/w cd.
