w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps
Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
