Question about Kwikset 909 909-L03 Lifetime Polished Brass Smart Code SmartCode Signature
None of the buttons on the device will work. Batteries are fine and blinking light inside appears normal. Cannont lock the device from outside or get the code to unlock the door.
Posted by d_shannon322 on
Grady Turner
    Scholar:
    New Friend:
  • 101 Answers
Check to be sure the keypad is still connected to the inside assembly. There is only a one year warranty on the electronics and Kwikset will not sell the electronic parts separately. If you want to replace it, there are other brands that are key-compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
Posted on Aug 26, 2011
The sat button on my remote is rapidly blinking, and now most of the other buttons will not work.
When the SAT button blinks repeatedly, or the buttons do a dance (Sat & DVD, TV & AUX, repeat) it means you need new batteries. Replace all four AAA batteries, ensure they are all four aligned the same way, and then hit SAT. Your remote should return to its normal function. If you leave the batteries out for too long, the remote will forget how to operate the TV and receiver, so be sure to have all four new batteries ready before you remove the old ones.
Oct 17, 2014 | DISH Network Televison & Video
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
The light continues to blink
LED light goes red (not blinking, just stays red) and none of the buttons on the lock work.
My reply:
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Jan 08, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Remotes won't open the door but the mechanism on the wall does. Batteries are fine.
Make sure the light in the wall control is not blinking rapidly. If it is press and hold the lock button for 3 seconds and release.
Check the LED on the back of the motor unit. If it is flickering rapidly then you have outside interference. Random flickering is normal.
If this is not the case it sounds like your receiver has failed. It is part of the logic board.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Outdoor device won't register inside.
All these wireless weather station devices have to be paired to the base unit whenever the batteries are changed in any of the remotes. It's a poor design issue, but there is no way around it, due to the nature of wireless operation.
Place both units near each other and look on the back of your base and remote sensor units, you should find a reset button (or a small hole). Either press the button or use the end of a paper clip to depress and hold the reset on each unit; Base 1st, then the remote 2nd.
After a brief moment, the remote should register with the base and you'll be back getting wireless readings.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Kitchen Appliances - Others
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
Jul 25, 2009 | Kodak Easyshare M753 Slim Digital Camera
"normal cycle" light keeps blinking
The blinking button indicates the button is bad. The button console will have to be replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Shutter will not close. Appears to be locked with shutter out. Slider is ok. Not batteries. Cannot take a photo. Nothing shows up on quick view. Red light blinks for a short time. Makes a beep sound....
it´s normal in that kind of cameras it can be fine but after u shoot one pic with flash will happen the same, to fix the problem u will need to send it to a repair centre, they will isolate some stuff inside to prevent that from happening.
Dec 27, 2006 | Olympus Camedia C-350 Digital Camera
Kwikset 909  909-L03 Lifetime Polished Brass Smart Code SmartCode Signature Logo
219 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
