Question about Goodman CKL30AR30 Air Conditioner
Hello, I have a Goodman ckl30-1p a/c and the fan no longer turns on if it is set to switch on. My son did turn on the unit during the winter for a few minutes. The temperature was not too low but now it does not work. I am assuming that it is a blown capacitor!
6ya staff
SOURCE:
Bob Gunn
  • 127 Answers
SOURCE: My Goodman CKL30-L1 is turning
access the electrical cover on the corner of the unit after disconnecting power and inspect for loose wires or bad capacitor, the capacitor has three different terminal connections on top and the top should be flat not bulged, if bulged,rounded in any way then the capacitor needs replaced. If the fan motor still does not work, then the motor will also need replaced. Note: capacitors can go bad without bulging or swelling, a meter for testing capacitors will verify uf(MFD)rating as printed on part.
Posted on Aug 24, 2011
Anonymous
  • 288 Answers
SOURCE: Goodman Heat/Air unit Model # A49-20 Serial # 9909502720
It sounds like the blower motor has burnt up.(the one inside) The unit running for a few minutes then shutting off, is due to the high pressure/temperature safeties. When you removed the panels, did you notice any fan running?
Posted on Feb 19, 2008
Anonymous
SOURCE: My Goodman GMP100-4 blower fan
Replaced capacitor and cleaned filter. Problem solved.
Posted on Jul 13, 2008
Anonymous
  • 340 Answers
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Posted on Jul 03, 2009
Anonymous
  • 26 Answers
SOURCE: I have a goodman furnace and ac unit the fan and
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Posted on Jul 07, 2009
Should the outside unit be covered with the conventional vinyl cover or should only the top be covered with wood?
Hello if you are asking about winterization, as long as it's not a heatpump unit that would be in use during the winter, you may tarp it with plastic. Or wood that's your choice If I misunderstood the question please respond back Thanks Bryan
Oct 25, 2013 | Goodman Heating & Cooling
Hello... I have a Goodman CKL49 a/c unit on the exterior of my house. I have checked everything I can think of and isolated the issue to the fan motor not turning on. The unit will recieve the signal from...
Hello, try using a small object to push the fan with power applied to it, if this gets the fan going tnen the capacitor must be replaced. If the fan does not start up then the motor is shot and must be replaced.
Sep 02, 2011 | Goodman CKL49AR49 Air Conditioner
In Fan mode, fan works; but in AC mode, I can hear the normal AC sounds, except the fan never turns on. This is the fan in the lower half of the unit in the inside of the house, which blows the air...
on a call for air conditioning your therrmastat brings the indoor fan on and the out door unit at the same time. Since your fan comes on in "fan" mode, it sounds like you need a thermastat. For temp. cooling just turn your fan switch to "on" and turn system switch to cool and set desired temp. System will cycle off and on but fan will not shut off until fan control is set back to "auto". I suggest replaceing thermastat
Aug 16, 2011 | Heating & Cooling
Condeser unit fan not turning.
Hello, most likely youmhave a bad capaitor or bad fan motor. If you push the fan and it gets going than the capacitor is bad,if not bad fan motor.
Jun 08, 2011 | Goodman CKL36AR36 Air Conditioner
Unit will Not turn on
Hello. There is usually a separate circuit breaker in an electrical box near the outdoor component. Chances are it was turned off at that location for the winter. Joe
Apr 03, 2010 | Goodman CLQ36AR49 Air Conditioner
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
A/C unit will not shut off
pls the connection of the thermostat is
C- COMMON
R- LINE
G - FAN
Y - COOL (compressr contactor)
W- HEAT ( heater contactor)
after you check the voltage 24 v between r and c slect cool then set thermostat at low temp the fan will start after the compressor will start
Apr 27, 2009 | Heating & Cooling
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Goodman CKL30AR30 Air Conditioner Logo
173 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Brad Scarpetta
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
