First onplug your refrigerator. Second Turn off you water supply before it reaches refrigerator. This will prevent shock, water damage, and possible electrical shorting behind and at bottom of the rear panel of your refrigerator. You are going to need examine the=> Dual Outlet Water Valve WR57X10051=> and test the==> Part Number WR23X10224 Dispenser Switch Unplugging power at top or bottom and sometimes hidden by kick plate or the top freezer door hinge cover plate there will be a plug that can be carefully disconnected. Doing this eliminates the long way of finding a multi problem solution. Here is your models Service manual=> PSS26MSRSS Service Manual to follow and disconnecting the plug under the cover of freezer door hindge will eleminate both dispenser pressure switch and the Click Here=> WR55X10415 Interface or HERE Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION I will be here should you have more questions, Thanks for using Fixya... Sea Breeze
