A lot of HP Deskjet F4200 Series All-in-One printer users complain about the installation problem experienced with this product, especially those using the Windows XP operating system. The driver installs perfectly; it performs the alignment and prints the test page. But as soon as you print a document, photo, or anything from the computer, the printer fails and says "The program has encountered a problem and needs to close". When you go to the printer properties, you'll get a message: Function address 0x500a0490 caused a protection fault. (Exception code 0xc0000005) Some or all property page(s) may not be displayed.
The problem can be resolved by completely uninstalling the driver and installing it again. When the installation is complete, click the START button on the lower left corner of your screen then on the right pane, click 'Printers and Faxes'.
Under the printer tasks, click 'Add a printer' then click Next on the Add Printer Wizard dialog box. Select 'Local printer attached to this computer' and uncheck 'Automatically detect and install my Plug and Play printer' then click Next. Click 'Use the following port' and select LPT1: (Recommended printer port) then click Next.
Select HP under the Manufacturer list and under the Printer list, select hp deskjet 990c then click Next. Select 'Keep existing driver (recommended)'; click Next, name your printer, select Yes to set your printer as the default printer then click Next. Select Yes to print a test page, click Next then Finish to complete the setup. Click OK when a dialog box appears.
Go back to the 'Printer and Faxes' folder and right-click on the name of your printer. Select Properties and click Ports/Connections then check 'USB...Virtual printer for.....hp deskjet 990c'. Click Apply then OK and you should now be able to use your HP Deskjet F4200 Series All-in-One printer.
Click on above link and download full feature and drivers for your printer then install in your mac.Connect your printer to usb ports of computer with usb cable while you install. Then it works
here is two different links you can copy and paste in your internet address bar. One is for instruction manual, the other is to download the software if you don't have it already.
Please follow the best option that are given :
1) Check all the cable.
2) Check you cartridge position and install it correctly.
3) Remove the old copy of your driver and try to download latest driver from http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=14438&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=usand install it.
4) If cartridge condition or its refill time is over then try to use new cartridge.
