Question about 3Com NBX 3102 IP Phone
I know this is old but maybe it can help someone else.
The line cards are "hot swappable and don't always reset with a reboot (especially a Digital Line card) you should try to re-seat the Line card after the system has booted up. This is done by unscrewing the black knobs at each end and then sliding the card out about an inch. Wait about 10 seconds and plug it back in. It takes about 2 minutes for the card to boot and synch with the phone company. Try your call again. If it's still not working after about 5 minutes, check the card in the phone system and make sure the channels are idle. If they are, call the phone company.
Posted on Nov 25, 2014
SOURCE: Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Posted on Jan 09, 2010
SOURCE: the msg button on 3COM nbx business pnone is not
There isn't any configuration needed on the Phone system or the phone to make this work. The light must simply have burned out. This would require a new phone to work (unless you know how to solder). f it's under warranty then you can get it replaced for free (1yr). you can also map a button on the right to light up/access the same mail box as a work around.
Posted on Aug 03, 2010
SOURCE: do you have experts in the 3com nbx 100 system?
Yes, you can call forward a number of ways with the NBX. You can do it from each extention or from a hunt group off of the Auto Attendant. The only thing you need to worry about is that for every call that is being forwarded it uses two phone lines. The line coming in and the one the system uses to call your cell phone. if you don't get a lot of calls or if you have more than a couple of lines, then you're good.
Posted on Aug 09, 2010
Apr 02, 2014 | 3Com NBX 2101 IP Phone
Mar 11, 2014 | 3Com NBX V3000 IP Phone
Sep 27, 2012 | 3Com NBX 3101
Apr 06, 2010 | 3Com NBX 3102 IP Phone
Feb 15, 2010 | 3Com NBX® V3000 (3C10600BUS)
Jan 28, 2010 | 3Com NBX® V3000 (3C10600BUS)
Mar 17, 2009 | 3Com NBX® V3000 (3C10600BUS)
Feb 12, 2009 | 3Com NBX 2102 IP Phone
May 08, 2007 | 3Com NBX 2102 IP Phone
May 05, 2014 | 3Com NBX 3102 IP Phone
Oct 10, 2013 | 3Com NBX 3102 IP Phone
315 people viewed this question
