You want to verify your wiring first. Use a volt meter to make sure the power and ground are good. You can jump the + to the Remote to bypass the head unit(after unhooking the remote wire). If at any point you had your speakers short out or wires hit together it will have smoked your power supply and damaged it internally. If you end up verifying the power and remote are working right and there is still no amp turn on, measure the fuse for resistance. Should be 0 ohms. If the fuse is good, the power/remote are good, then the amp is internally damaged. Any number of things could be wrong. Good luck
SOURCE: what is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
SOURCE: car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
SOURCE: where do i can find the electrical diagram for
There isn't one. You will need to contact Pyle and I am almost certain you won't be able to get one for free. Expect to pay $20 for one
SOURCE: is the pyle pla-1200 bridgable?
This appears to be the manual for several amps, including the pla1200
http://www.pyleaudio.com/manuals/PYLEChopperamps.pdf
If your amp is the same as in this manual, it is a mono amp (or one channel) amp. There is no need to bridge with a mono amp as it has only one channel. The diagram specific to pla-1200 is on page 20 of the manual.
