SOURCE: Ebel Classic Wave fitting a new crown
don1421's answer is not going to work because it's not possible to remove the back of an Ebel Classic Wave. It may need to be sent to LVMH for repair.
SOURCE: My wifes Ebel watch band
Unfortunately it is not possible to do it yourself as special tools and skills are needed.
You can bring your watch to the nearest watch repairer or find the nearest EBEL dealer here:
www.ebel.com - Cached
Note: sometimes it is not possible to repair or renew stretched links and replacement of band is necessary.
SOURCE: new band for ebel wave or repair possible?
Paste this link into your browser and find what you want:
http://www.ebel.com/#Stores_Service_Centers
Do not forget to rate, please.
SOURCE: Need double link for mini Ebel Classic Wave Watch
Unfortunately you will not be able to buy links anywhere else exept Ebel. You can try to find them on eBay, but it may take years and even then there is no any guarantee thet you will find the right links.
The best way is to contact Ebel and ask them if they can supply any links needed. Visit this link:
Choose the way you want to contact them or the nearest srevice center.
SOURCE: I want to replace the battery in my wife's Ebel
After removing the 5 screws and the glass with seal, put your screw driver und the opposite edge to the winder. By carefull lifting,(do not force) you will find the inner watch assembly lifts out enough. to access the battery. The winder spindle has a joint in it which allows the body to bend on it to almost 90 degrees.
Hope this is helpfull
