RCA HD52W59 HDTV Projection Television Logo
Posted on Oct 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im trying to change the picture size on my floor modle rca hdtv television, all of a sudden the size of my picture changed, cuttin of the heads of any move that i watch or any channel that i watch because the picture is too big how to i get it to go back to normal? i do not have the original remote i had to purchase the rca univeral remote
Marvin
Level 3:
Top Expert:
  • RCA Master 85,242 Answers
  • Posted on Oct 26, 2017
Marvin
RCA Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29025595
Points
266281
Without the OEM remote you can't access that video menu to change this aspect ratio. Have you looked on eBay for an OEM?
5 Related Answers
Anonymous
  • 1030 Answers
  • Posted on Mar 24, 2008
SOURCE: rca D52W20 changing picture size
CHANGE autoformat in customer setup menu
Anonymous
  • 1030 Answers
  • Posted on Oct 29, 2008
SOURCE: RCA HD52W56 52 in. Rear Projection HDTV Television
turn off autoformat.. to change format push left or right arrow over on your remote
Anonymous
  • 5138 Answers
  • Posted on Feb 13, 2009
SOURCE: Picture NOT Alined
Use the zoom for picture adjustment.
Anonymous
  • 1139 Answers
  • Posted on Jun 14, 2009
SOURCE: television will not power on after power surge
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
Anonymous
  • Posted on Sep 17, 2009
SOURCE: RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
Picture is too big, No remote to change size. Can i change the size from the front of the television?
Sorry, no. The only thing you can change is the color balance on your tv. Unless you can locate a "menu" button on the external of the tv this will be the only way to adjust picture size is within the menu.
Thank you!
How can i change the aspect ratio on RCA mm52110. the HD picture is stretched tall but very clear.
I'm going to take a stab at this out of the dark but okay!
1) is there an 'Aspect' or a 'picture size' button on your hand held remote control?
2) If you scroll through your 'On Screen Menu's' do you find a feature that will change the aspect or picture size?
Many of these TV's have this button feature on the remote control.
Blessings,
A/V Media Tech Guy
Picture does not fit screen. People head is chooped off.
I have heard that using the directional buttons on the remote left or right changes the picture format. I believe you should also be able to go into the menu and change it there.
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
2answers
50Inch RCA dlp Scenium
Its the color wheel assy. Its changing speed due to worn bearings. You may also hear a hum coming from the rear of the TV. Seek an RCA authorized service center to resolve this.
michtech
Picture NOT Alined
4helpful
2answers
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
