Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
