1) You must see if the circuit where the microwave is overload, you must use the amperimeter and see how many amperes are reading when all the load in the circuit 7 are running. if is normal about 10amp-12amps the circuit is o.k
2) test the c.breaker can be faulty, since there are NOT tripped.
3) However you must see if the lines for power in that circuit is loose?
4) Tight very well the Neutral +Ground
5) see the diagram attached, and correct if the outlet is wrong.
6) If you are NOT qualified to do this electrical job , call some electrician for to avoid danger to your home or yourself.
God bless you
Of course you must test the microwave magnetron for faulty or short in the magnetron+diode+transformer+capacitor. ISOLATED the microwave first and then troubleshooting the circuit of your home.
God bless you
By the way, we can tell when it heats because the humming sounds slightly different. And when it switches from non-heating to heating (or vice versa), it sounds like the hum "switches gears", so to speak.
