Question about Samsung Refrigerators
Samsung SR518DW freezer works fridge section not cooling
Posted by dho13237 on
D. Floyd Kolb
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 06, 2011
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Frig stopped working but freezer is good? Help... I am handy.
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 24, 2011 | Maytag MFD2561HE Bottom Freezer French...
NEFF K4663 fridge. the freezer works ok but refrigerator space does not go below 9deg C even at highest setting. have defrosted and water drain is clear.
The defrost board is not functioning properly.;
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Neff Refrigerators
My samsung fridge section stops cooling but freezer is working
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Samsung Refrigerators
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
Samsung fridge problem
You need to post in the correct section of Fixya, you may then get the answer you seek.
Jan 04, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Refrigerators Logo
304 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
