Question about Goldstar GBV241 DVD Player/VCR
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Posted by apalmer12 on
  • Goldstar Master
  • 6,102 Answers
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Posted on Aug 06, 2011
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Feb 11, 2012 | Zenith Televison & Video
I would like to tape my programs on the vcr(goldstar) I am not used to this product
do you wish to record while watching or while away.....while watching make sure your vcr is set to CH 3...when the show comes on press record
(a blank tape should be inserted) the red button on most vcrs.......while away the channel selector must be on the ch you wish to record...using the remote for the vcr press menu/program a event (this is where your vcr most have the correct date / time and not flashing 12:00)..set the day..time to start recording and time to stop recording..your ch will always be 3..now that vcr is set the main thing is make sure that cable channel selector is on that channel
happy recording
Aug 08, 2010 | Televison & Video
How do i hook up my old admiral vcr to my new rca flat screen tv to tape american idol?
Do both have Scart sockets? If they do you can get a scart lead. All you have to do is set the VCR to the AUX setting that the scart is on and press record!
You won't be able to watch another channel though whilst recording. If you are using the scart socket for say DVD (on the TV) you can get one of these:fa1357d.jpg
Feb 21, 2010 | Goldstar GVR-E435 VHS VCR
Remote code
Manufacturer Codes
LG/Goldstar 1, 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
That is the whole list from the manual
Dec 31, 2008 | LG RC897T DVD Recorder/VCR Combo
Can only get DVD audio when hooking it up to Goldstar VCR...
The DVD must be connected with the RCA jacks-plugs [usually black & red] to the INPUT of the VCR, not to the RF connector. You must press the VCR\TV button to VCR so that the VCR takes control.When you place a DVD movie or AUDIO program it could be copied to the VCR. or played through the VCR.
Nov 11, 2008 | Televison & Video
Vcr
In the setup menu there will be a screen that lets you change from <AIR> to <CABLE>. When that is done, do an automatic channel setting or programming. That should do it. If you have trouble leave a comment and I'll follow up.
Oct 01, 2008 | Goldstar GVR-E235 VHS VCR
Need remote codes for Goldstar VCR/DVD combo player
No model # so here are all.. 002 102 117 207 217 307 502 819 914
Feb 10, 2018 | Goldstar GBV241 DVD Player/VCR
Input
Usaly there is a button on the remote for input but if you do not have that you might try changing chanels below chanel 1. Some Goldstars hide the front input down there
Mar 03, 2008 | Goldstar GVR-DD1 VHS VCR
CONNECTING A VCR RECORDER/PLAYER TO A HD FLAT SCREEN TV
Now one question - Do you want to record the TV program on the VCR or Movies from a DVD plater hooked to your HD TV?
Jan 10, 2008 | Goldstar GVR-E435 VHS VCR
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
Televison & Video Logo
323 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
 Mikey
Mikey
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
