Question about LG DLE0332 Gas Dryer
LG DRYER DLG0332W GAS - LG DLE0332 Gas Dryer
Posted by jtkschlegel on
  • mike
    mike Aug 05, 2011
    hello there, whats the problem?
D. Floyd Kolb
  • LG Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[[]
Posted on Aug 10, 2011
DLG0332W LG Propane Dryer, intermittent heat problem? Heats in the morning (when cold). Any ideas?
It seems to me that there is a problem with your valve assembly . I would check the connectors to the valves there should be 2 coils in there those do funny things when thy are defective.
Oct 30, 2014 | Dryers
Tip
DLG5932W Service Manual
Some sites make you pay for it... but I found it FREE.
Here --> http://www.appliancefactoryparts.com/content/pdfs/129227-8.pdf
Also applies to:
DLE5911W
DLE2511W
DLE5932W
DLE5932S
DLE2532W
DLE0332W
DLG5911W
DLG2511W
DLG5932W
DLG5932S
DLG2532W
DLG0332W
on Apr 29, 2009 | LG DLG5932W Gas Dryer
I have a DLG0332W everything was having some problems with the drum not spinning went in and clean everything and now it stoped heating just cold air
seems to me you may have inadvertently disconnected the heater coils or you may have damaged the coil. Open the machine again, and check all the connections before you buy anything else for it. It could be that simple.
Joe
Sep 13, 2011 | LG DLE0332 Gas Dryer
Hi: I have a LG DLG0332W Dryer, which is running but drying. I cleared all the lint areas still nothing. Is there anything I can do, I am pretty handy. Thank You.
on the right side there is an access panel, unplug dryer, open it up and look inside you will see two wires and in the middle is a reset button, push it in and it shall dry
Feb 27, 2011 | LG DLG5932W Gas Dryer
I have an LG DLG0332W gas dryer and it not getting hot. Read that the thermostat my need to be reset. have the dryer torn apart and I am having trouble locating the thermostat reset button. Where is it?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Dryers
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Thermal cut off
The thermal high limit is located on the side of the flame tube part number Y61886 You also can visit my site and enter model or part numbers in the search feature. We also offer free assistance. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jan 20, 2009 | LG DLG5932W Gas Dryer
Not properly drying
If you remove the front cover hitting the reset switch is rather easy. However I did that the other day and only got 1 load done before it tripped again.
I just picked this dryer up used from a buddy the other day and am already having trouble. Also... It runs very loud. How loud is yours complared to the washer?
May 30, 2008 | LG DLE0332 Gas Dryer
LG DLE0332 Gas Dryer Logo
242 people viewed this question
Top LG Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
