SOURCE: inside the microwave the piece
Yes. This is the waveguide cover, and it needs to be there to protect the magnetron from damage.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet or held in a slotted opening.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
If your waveguide cover is burned or damaged, it will need to be replaced.
You can often find helpful exploded view diagrams and order parts by entering your full model number here or here.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: interior cardboard/foil piece fell off revealing small chamber inside oven--still safe?
This is the mica or plastic waveguide cover. It protects the waveguide and magnetron form grease and food particles.
Assuming you're going to scrap the unit, carefully clean the area around the outside of opening (watch for sharp edges) with a lightly damp soft cloth.
Then use alcohol or a hair dryer, etc. to be sure the area is dry.
Then you can use a couple of strips of clear packing tape to cover the opening and trim it with a razor blade so only about 1/4" or so extends out from the opening.
Note that I only recommend this procedure on an oven that is going to be scrapped. If the oven will see continued use, a new waveguide cover should be purchased.
SOURCE: Set up Oster Microwave
No, that is the "waveguide cover".
It provides very important
protection for the magnetron.
And always keep it clean according to your manual's instructions.
We're
SOURCE: Rust inside the microwave oven
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
SOURCE: IS MY MICROWAVE NOW UNSAFE TO USE - CAN I DO OWN HOME REPAIR?
It sounds like what you are describing is called a "waveguide cover". You can purchase a replacement from a local parts supplier, or on-line at www.repairclinic.com. It is very easy to replace.
