The A10 direct connect cord used on the Nortel T7316E primarily will
increase the speaker volume. If the problem is that your microphone is
too low, you will need to use an amplifier, the M22. Remember that the
amplifier needs to be connected through the HANDSET jack not the headset
jack. Here is the link for the Plantronics M22.
Good luck from Headsets Direct!
Plantronics offers the A10 direct connect cord
which is an amplified cord to help boost the volume of the built-in
amplifier of the Nortel phone. If you're already using the cord, there
are a couple other things to keep in mind. First, you may need use an
M22 amplifier, keeping in mind that you will need to connect it through the handset
jack on the phone. Second, if you're using a noise canceling headset in a
quiet environment and your voice is the only sound the microphone picks
up, it will soften your voice and you may need to go with a voice tube
headset.
We have the A10 direct connect cord already. We may need to invest in the M22 amplifier to permanently resolve the issue -- at least until we can get a noisier environment!
Thanks.
