Question about One For All Kameleon URC-9960 LCD Touchscreen Remote Control
The code of my home theater (Sony BDV-E570) listed in remote manual ( Kamaleon URC-9960b01) doesn't work. Do you have the right one?
  • Anonymous Aug 05, 2011
    Hi!
    I don't think this is a solution. I want my money back!
    Best regards
    Top Expert:
  • One For All Master
  • 76,763 Answers
Hello
That is I wonder about your problem post! No universal remotes have the codes for Blu-Rays so far. You haven't try for that. You can synchronise other devices like TVs, VCRs, DVDs and so n, but not with Blu-Rays. The remote control you posesses now is one amoung the greatest one universal remotes we can get from market. Not waste your time for this purpose. Try to get its original number remote control from Sony. Just contact the nearest Sony Authorised Service center. They can provide you the original number remote handset. If you don't know the number of the remote control, isn't matter, just give them the exact model number of your device. OK.
Posted on Aug 05, 2011
  • The Knight
    The Knight Aug 05, 2011
    Hello=You just take it back. I'm not greedy for money. I've got more than enough than I expected from my past 42 years of this electronic equipemts service field, and now too is going on smoothly. Anyway, you won't get a UNIVERSAL REMOTE HANDSET for your device. OK.
What is the code for the Sansai Universal Remote Control URC-501A to connect with Sony Home Entertainment BDV-e2100
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
Issue programing Motorola Remote VIP2262 with Sony Bravia Home Theater System BDV-N890W/N990W
Motorola remote control have no setup codes to Sony Bravia HTS. If you wish to get some details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
Motorola remote and sony home theater system code
you may need to set it up as two devices program a code for DVD to turn the unit on and off and a program and auxiliary code so that you can control the volume then you can teach the remote to use the auxiliary volume without having to press the aux button each time
Sony BDV-E370
From page 68 of this manual: "Contact your Sony dealer or local authorized Sony service facility."
2helpful
2answers
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
2helpful
I need the three digit code for my Sony BDV-E370 home theater remote controller.
The RM-ADP053 comes in the box with the BDV-370 and is preprogrammed with the codes to operate that unit. The manual can be found at Sony at this link.
To reset the remote control back to factory specifications, press the POWER , TV/VIDEO , and VOL- buttons simultaneously.
2helpful
I need the manual for the one for all remote urc-9960B01
http://www.hifi-remote.com/manuals/manual.shtml?URC-9960
1helpful
2answers
Need the code for Philips Home theater system model HTS6500
  • I will list some codes. The manual for this remote does not list a theater system at all. That does not mean one of these code will not work. It may be a bit more challenging to figure out which "heading" the code exists.
  • Four codes are listed for a Phillips DVR/VCR Combo from the manual for this remote.
  1. 145
  2. 067
  3. 101
  4. 034
  • DVR Receiver code
  1. 001
  • There are some codes marked under "Audio" as well.
  1. 249
  2. 250
  3. 063
  4. 805
  • Here is the manual as well http://www.universalremote.com/resources/pdfs/avex_manual.pdf
  • Please keep in mind that it is completely possible that the remote you have may not be compatible for that home theater system.
  • Should this be the case you can get a universal remote that is very inexpensive (often times less than $10) that will seek and find codes removing the seeking number code trouble.
  • These remotes you aim at the device you want to use and it finds the code for you, hassle free.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
2answers
Need a universal remote control code for sony dav-dz 100
use kameleon urc remote there are a list of codes in back of manual one of the sony codes will work
One For All Kameleon URC-9960 LCD Touchscreen Remote Control Logo
Top One For All Televison & Video Experts
Ekse
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
