Question about Westinghouse Televison & Video
WHAT THE CODE TO PROGRAM A WHITE-WESTINGHOUSE OLDER MODEL TV
Posted by wood3130 on
    Top Expert:
  • Westinghouse Master
  • 76,416 Answers
Hello
Three digit universal remote codes for White Westinghouse TV are:
097/ 100
Four digit codes are:
0227
0279
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK
Posted on Aug 05, 2011
  • vidal chavez
    vidal chavez Aug 05, 2011
    Just to add one thing to gopakumarg43 great post, please note that most of the Westinghouse older models use SONY codes which are posted on your remote control booklet with all the codes. Also unless you go very old they where no longer White Westinghouse TV's but only Westinghouse as they are now made by a different manufacturer. Just some food for thought.
  • The Knight
    The Knight Aug 05, 2011
    All the codes I've given you are for White Westinghouse TV itself. I've got it from a great site. All other codes I give to other brands; including this White Westinghouse you reports here are from that code list. They are not for sony. sony has different codes list and all are with me now. OK.
Set up my universal remote without my westinghouse tv code.just switched from directv to charter.com and technician wasn't able to program the remote to turn TV on and off
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 14, 2014 | Televison & Video
Westinghouse 32H540S Remote Program
You have this backwards. The codes are in the remote. If you are using a Westinghouse remote, there should be no programming necessary. If you are using a universal remote, you can use the code search function to find a code that will control your TV.
Dec 03, 2013 | Westinghouse SK-32H540S 32 in. LCD TV
The conyrol of my tv, westinghouse model sk:19H2105 IS BROKEN AND I NEED A CODE TO USE A UNIVERSAL CONTROL PLEASE HELP ME, THANK, YOU.
Hello
WHITE WESTINGHOUSE Codes: 097/ 100
Four digit codes for white westinghouse are : 0100 0130 0138 0136 0227 0279 0080
four digit codes for wetinghouse are: 0143 0114
OK
Jul 25, 2011 | Televison & Video
Need the code to program remote to tv remote is a sru2103 tv is westinghouse
Hello
Codes for Westinghouse is:
0000, 0451
Code for White Westinghouse is:
0463
OK.
Jul 17, 2011 | One For All URC4220 Remote Control
I can get my dishnetwork remote to program for the volume nor to turn it on or off help me please the model #w32001
We would be happy to help you with that.
Step 1:
Press and hold the TV button until all mode button back lights come on, then release.
Step 2:
Use the number buttons to enter the device code corresponding to your Westinghouse TV. Potential codes for White Westinghouse are: 500, 719, 664, 555, 674, 659, 670, 672, 641 and 573. Then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. Your DISH Network remote should be able to control your TV. Thanks for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
Jan 20, 2011 | Westinghouse W32001 20 in. HD-Ready LCD...
I am looking for the universal remote code (mine is a Sony RM-EZ4 remote) for an older model of White-Westinghouse 13" colour tv. Model # is: 61304. I have tried several 4 number codes I found on the...
Use the code search function of the remote to find something that works, even to a limited extent. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jun 24, 2017 | Westinghouse Televison & Video
White westinghouse tv code for remote control? And the procedure to program it.
pepelule
Here are the codes for your White Westinghouse TV: 719, 500, 659, 664, 670, 672, 674
I have also included the instructions for programming the remote to your TV. I hope this helps.
  • Remotes: Basic (Television Only)
    1. Turn the Television On
    2. Press and Hold the TV Power button for three seconds until the LED flashes
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Oct 25, 2010 | DISH Network IR Remote Control
White Westinghouse sk26h240s remote codes
Goto this page:
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/grayokselect.pdf
follow the instructions for "Searching For your Code " This worked for my White-Westinghouse (though it takes about 20 repetitions to hit the code!)
Hope this helps
Nate Wells [email protected]
Jan 10, 2009 | Televison & Video
Directv remote code needed
Follow these steps:
http://support.directv.com/app/answers/detail/a_id/3188/~/white-remote-control-programming-steps
When it asks you to enter the code for your tv use 10178
It works like a charm!
May 01, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Nov 10, 2007 | Westinghouse 16093 Remote Control
Televison & Video Logo
579 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
