HP Compaq dx2450 Microtower  PC Desktop Logo
Posted on Aug 05, 2011
HP dx2450 ahci. How do I enable\disable AHCI in the BIOS on an HP DX2450 computer, 64 bit AMD processor?
3 Related Answers
sodeep
Sudeep Chatterjee
  • 3267 Answers
  • Posted on Mar 20, 2009
SOURCE: hp dx2450 no sound device installed
You will have to install a new sound card if your guide/handbook does not mention in-built sound capabilities....sodeep
tdk1988
  • 121 Answers
  • Posted on Jul 09, 2009
SOURCE: My HP compaq dx2450 can't install Windows XP. I
make sure to use a bootable win xp setup disc
and the message (insert system disc) means that the system was unable to find a boot sector ie the hard disk or the xp setup disc
Anonymous
  • 3153 Answers
  • Posted on Mar 15, 2011
SOURCE: ello. I wanted to know if
The AHCI can be enabled from using the correct driver but you should have enabled it PRIOR to the OS install
Acer did not always do this but often relied on compatibility mode
The speed increase is often not that much.
The BIOS on that board can be updated but you may find that AHCI still does not work as you expect.
How to unlock amd phenom core hp dx2450
Not much point really. The unlocked cores are probably defective.
Some processors with 4 cores ar sold as 2 core because they have a manufacturing fault on one or more cores. The faulty cores are locked because they don't work properly and would cause problems with the correct running of the processor.
2answers
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenomâ„¢ FX / Phenom / Athlonâ„¢ / Sempronâ„¢
AMD Cool 'n' Quietâ„¢ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenomâ„¢ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
2helpful
Ello. I wanted to know if there is a BIOS update for the Aspire M1100 because my BIOS dated 23/02/2008 which references are Motherboard SMBios version 2.5 Acer F690GVM Bios: Phoenix Technologies,...
Can't find updated ACPI Bios for toshiba satellite m45 s331. If found how to install? Getting blue screen Bios in this system not fully ACPI compliant.
I already explained in the other post ..The action required is either install a 3rd party raid and ahci driver ..and if you do not have the possibility ..just c\go to bios and enable the hard disk bus to work as ide..(disable ahci mode) I'm not sure how it will appear ..but you have to look under the bus mode..where the hard disk is seen ..It will appear as ahci enabled..and need to be disabled or ..will have raid mode enabled..and need to set it as native ..or ide compatible
I have toshiba satellite L505-S5990 model.i have installed windows xp by changing the settings in Bios that is sata hard disk enabled as compatable mode from AHCI.if i change to AHCI i can't install...
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Read more: http://www.techmetica.com/howto/sata-ahci-mode-bios-setting.-what-does-it-do/#ixzz0y5ObAtN8
My HP compaq dx2450 can't install Windows XP. I tried with many diferent versions (most of them were speciffied to work with AMD 64-bit processors), but allways recieving same message (insert sistem disc)....
2answers
Hp dx2450 no sound device installed
1helpful
2answers
Could not make it work in AHCI mode
what kindda chipset your laptop is?
It's must obtained in your OEM site
1helpful
Windows XP boots endless if SATA is set to AHCI
this is'nt so easy here an example solution:
Enabling SATA mode to AHCI after XP Install (applicable to most laptops, or systems) If you want to enable SATA mode as AHCI after installing Windows XP, then read on. It's a bit of a long read because of step-by-step instructions, but worth it.
I did this on on Acer Aspire 5315-2153, it seems like the basic strategy should work on other laptops or systems.
For whatever reason, you may have installed Windows XP on your new laptops with SATA Native Mode disabled in the BIOS. Once XP is installed, enabling it in the BIOS will result in a BSOD upon loading Windows because XP doesn't have the correct drivers.
I read that enabling SATA native mode will give you a slight performance inrease and slightly increased battery life, so it seems worthwhile to me smile.gif
Here's how I did it on a Acer Aspire 5315-2153 running Windows XP (32 Bit version):
- Download the Intel Matrix Storage Manager software from Intel (I think it's iata_enu.exe)or AHCI_Intel_v7.5.0.1017_XP.zip from Acer web site.
- Extract files from AHCI_Intel_v7.5.0.1017_XP.zip to e.g. C:\AHCI_Intel_v7_5_0_1017_XP files need: (you may delete the rest)
iaahci.cat
iaahci.inf
iastor.cat
iastor.inf
iastor.sys
TXTSSETUP.OEM
- Now go to Device Manager, under IDE ATA/ATAPI controllers you should
see: Intel 82801HEM/HBM SATA AHCI Storage Controller
- Right-Click on that and select Update Driver
- Say no to connecting to Windows Update to search, hit Next
- Select Install fro a list or specific location (Advanced), hit Next
- Select "Don't search. I will choose the driver to install", hit Next
- Select Have Disk
- Browse to C:\AHCI_Intel_v7_5_0_1017_XP and highlight the iastor.inf file, hit Open
- Select OK
- Now you should have a list of controllers, for the Acer 5315-2153 choose Intel 82801HEM/HBM SATA AHCI Storage Controller, hit Next
- You'll get warned that installing the device driver is not recommended, click Yes to continue installing
- Click Finish
- Click Yes to restart your computer
When your computer boots up, you need to hit F2 to enter the BIOS. Change SATA mode to AHCI, save changes and exit.
After you log into Windows, your computer will find the "new" hardware. Wait until you get the popup message to restart your computer, say Yes to restart one last time.
You may download also from Intel the RAID/AHCI Software - Intel® Matrix Storage Manager (iata70_enu.exe 5640KB) and install it in your system, it may fix in case you got the wrong Intel 82801 AHCI controller.
I give credit to Jamie Rybarczyk at HP Business Support Center forum for doing most of typing.
http://forum.notebookreview.com/showthread.php?t=186471
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
