Question about Altec Lansing VS2121 Computer Speakers
I need a new driver download for my Mac to connect my VS2121 and can only find PC drivers. My speakers quit working and I removed the driver from the computer, then could not find the disc to reinstall. Thank you for your help!
4 Suggested Answers
ginko
Ginko
  • 19396 Answers
SOURCE: driver/installer
Here is the 221 download page: http://www.altec-lansing.com/product_details_intl.asp?country_code=pk&region=northam&pID=221
cheers
Posted on Feb 16, 2008
heba95
SOURCE: bx1121 speakers not working with computer
Multimedia Speaker Computer Speakers
Posted on Jun 05, 2008
Anonymous
  • 81 Answers
SOURCE: Speakers are no longer recognized by computer
yes
Posted on Nov 11, 2009
stevem727
SOURCE: altec lansing vs2121 model speakers blown
I have the speakers ( in perfect condition) but can not find the base unit. Do you want to sell your base unit ? Or do you want to buy the speakers ?
[email protected]
Posted on Aug 13, 2010
Do you need a driver instaled to use these
yes you need sound drivers
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list
Dec 20, 2010 | Altec Lansing VS2121 Computer Speakers
I can turn speakers on but when I play games there is no sound
try to install your sound (audio) drivers and try to insert the pins in line in ports your work is done...
Jan 20, 2010 | Altec Lansing VS2121 Computer Speakers
No sound - computer message says can't locate audio visual. Computer had been previously wiped clean because of a virus. Can I download and reinstall software? Make of speakers VS-2121?
It's not your speakers that are the issue most likely (as long as they are round ends with sort of a point (not sharp just like a .5" length cylinder like .25" thick) instead of a rectangular USB connection. If you post more information about your computer we could probably direct you to the drivers you need to download in order to resolve the issue.
Dec 21, 2009 | Altec Lansing VS2121 Computer Speakers
I need a generic web cam driver for Power PC G5 Mac OS X 10.4.11
http://www.cdrking.com/local/downloads/index.php?title=PC%20Camera
this is a link for the drivers an manual ...I studied the problem ..but its doesnt seam to get a driver for MAC ...this one suports all windows .. I thought ya might gave it a try ...
Apr 09, 2009 | Computers & Internet
Altec Lansing VS2121 not working
its best way to check the problem whether hardware is not working or any driver related in computer,
1) hook up any working head phone in your pc's head phone jack (generally of green color plug)
2) checkout that both LH and RH side speakers working!!
after that we can guess.
Dec 18, 2008 | Altec Lansing VS2121 Computer Speakers
The speakers and sub are not playing and sound. vs2121 amplified speakers
What OS are you using sir? Do you have an existing speakers before that worked? try your new speakers on another computer with existing and working speakers. So, that we can isolate the problem,whether of your pc or your speakers.
thanks
Jun 20, 2008 | Computers & Internet
Help
ok if im getting what your saying
the port of the computer for line in is not recognizing the sound of your sterio
ok there should be extra jack on speaker wire that should goto line in on computer
computers dont find these jacks cause there already predetermind when the cards drivers was installed
hook the jack to line out speaker out port if the speakers are powered find the power on them turn up
then goto your sound setup get to your volume controls and find the volume controls that are muted and or turned down even in advanced settings
if you recently changed your sound card you also want to be in the sounds setup and make sure that the propper software driver is connected and not the old one still in its place sometimes new drivers dont set the old drivers aside but it adds to the sound setup list
you will find the sound setup in control panel
also there is that slight chance you will have to reinstall software again
hope this has some help for you seeing i have no way of actually seeing the speakers in person and how they work
May 17, 2008 | Altec Lansing VS2121 Computer Speakers
Hi
Looking at the manual http://www.alteclansing.com/downloads/EUR/VS2121%20manual.pdf page 3 of the pdf says Connect the lime green 3.5mm stereo cable (hardwired into the right satellite) to the lime green input labeled ?FRONT? on your sound card. So your right speaker should have a cable with a green end that plugs into your standard audio out jack If you have multiple outputs and don't know which you are set up for, then turn the speakers on and up, put a long song on, and plug that green wire into every jack on the PC! If you've got no other issues you'll hear something! Good Luck
Aug 28, 2007 | Altec Lansing VS2121 Computer Speakers
My Altec Lansing Speakers aren't working
Try rolling back soundcard drivers. I had the same problem when Win XP updated my soundcard drivers.
Jan 16, 2007 | Altec Lansing VS2121 Computer Speakers
Altec Lansing VS2121 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
