Tip & How-To about Vehicle Parts & Accessories
How to Fix Hyper Flash without Resistors
Check the article below, plz
Vehicle Parts & Accessories Logo
color shadows
Tv have convergence problems.Ur tv have a "Hyper board" the tv Hyper board convergence are dead on it.The 2 STK convergence ICS and some or all it resistors are dead.Must changes these parts to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Can the VARAD HYPERLED tubes (24 LEDs each, be used without a controller. The only thing I know is the 20 MegOhms or so DC resistance.
Then you should be able to install resistors of the same size in-line before the LED's and have the same effect as the control box...Check radio Shack for the resistors, shrink tubing. Good Luck!
Toshiba 65H82 Projection TV; location of Convergence resistors
The caps will bleed off within a few minutes of being unplugged. I don't know which caps and resistors he was telling you about but here goes.
Typically along with the convergence IC's the output resistors under the heat sink are at least checked with a multimeter. They are large resistors and should match their color code markings. The caps are probably the caps in the hyper module (hyper board)
Here is a very good tutorial to do this repair or get it done: http://www.dshosu.com/how-to-fix-toshiba-rear-projection-hdtv-wavy-lines/
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
