Tip & How-To about Video Game Consoles & Games
Sony Playstation 1 replacing the power unit
Before you start make sure that the console is turned off and unplugged before you begin the process. This is for the 1001 model types. With the 5501 and the 7001 and for the 9001 the process might be slightly different.
Step one: Open up the PS 1 console with a Phillips head screw driver and turn the console upside down and remove the 5 15.8 mm-long Phillips #1 screws.
Step two: While holding the top and bottom halves of the console together turn the PS 1 console back over. Lift the top cover straight up to remove it.
Step three: Unplug the power supply and then gently pull out the power supply cable straight up and out of its socket on the power supply to disconnect it.
Step four: Now remove the power supply and then remove the 2 14 mm-long Phillips #1 screws securing the power supply to the bottom of the case.
Step five: Lift out the outer edge of the power supply slightly, and then rotate the whole entire power supply away from the small clip on its inner edge to remove the power supply.
To reassemble your PS 1 console back together follow the above steps in reverse order.
Compare your new replacement part to the original part You might have to transfer the remaining components or remove adhesive backings from the new part before installing.
Video Game Consoles & Games Logo
sony playstation model scph 5501
This is the optical laser lens - the motor is bad, or perhaps some bad gears. There is one for $19.99 - but make sure it fits your version of PS1 - they made a few models back then.
You can get a new one here.
Amazon com KSM 440BAM SONY PS1 Optical Laser lens by Besram Laser Pointers...
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
bought viper 5501 yesterday.started car with remote but when i put key in ignition car stops running when key is removed car starts automaticly
Make sure you turn the key to the on/run position, then once you place your foot on the brakes to put the vehicle in gear the remote will beep and recognize the alarm.
need help!
they do that when the door where the game is installed has a problem also make sure the lens has no finger prints on it dirt will stop it also.
Top Video Game Consoles & Games Experts
Marvin
Marvin
Aron
Tom Chichester
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
