Tip & How-To about Canon Office Equipment & Supplies
How to find canon printer default Wi-Fi password
If you need help how to find canon printer default password? Need not to worry this article can help you to find default Wi-Fi password of you Canon Printer easily. Follow the technical steps mention in article below and get canon printer default wifi password of your Canon Printer in sort span of time.
Get Canon Printer default password. Generally, setup a Canon Printer default password is not difficult but sometimes, Canon Printer requires technical steps to figure out. Steps are mentioned in article - How to find canon printer default wifi password
Steps to Find Out the canon printer default password Easily
https://fixofflineprinters.com/how-to-find-canon-printer-default-wifi-password/
First, start the web browser.
  1. There is print serve name used in some Printer.
  2. Next, type in the default log in password of Printer.
  3. then, click on the admin (Administrator) tab on Printer.
  4. If there is no such tab, next tap on Printer Login Password.
  5. Hence. Now you can type in the new password that you want to use.
  6. Now Confirm the New Password and then click set the new password.
  7. Finally, click on Submit.
2answers
My Canon MG6120, which worked on wifi fine for months, now doesn't. It still works with USB connection, but that's not the point of a wifi printer! How can I fix this?
First check with another device that your wifi is working if it is try resetting up wifi on your printer.
If someone changed your wifi password you will need to enter the new password.
2answers
printer needs password
search bottom or back of the printer for a sticker with the password
old marine
old marine
 Grubhead
Grubhead
