Tip & How-To about Computers & Internet
Fix: After Windows 10 Kb4560960 Update Cannot Print
  • On your Windows 10 computer, open the Settings app by pressing the Windows + I shortcut keys.
Alternatively, click the Start menu and select the Settings icon to open the Settings app.
Next, click the Update & security tab and select the Windows Update option from the left-side panel.
For more Laptop Support our technical expert will guide you for the best solution
Computers & Internet Logo
2answers
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Magic key
Install the driver of the keyboard.
find the library or executable which loads the user environment commands and put it into Win.ini or sinply dropit int the "Strat- AutoRun" menu section.
On Windows 7 and earlier versions of Windows, the Start menu contained a "Startup" folder to make this easy. On these versions of Windows, you can simply open your Start menu, locate a shortcut to an application you want to start automatically, right-click it, and select Copy. Next, locate the Startup folder under All Apps in the Start menu, right-click it, and select Paste to paste a copy of that shortcut.
Grand Canyon Tech
Grand Canyon Tech
