Tip & How-To about Heating & Cooling
How to ask for help with HVAC Units
When asking questions on HVAC units or issues with heating and cooling equipment, we will ALWAYS need the model number of the affected unit as well as the model number of any other units attached to the system with the issue.
Also, the relative age or serial number of the units also helps, as well as any pictures you can link to.
Also, be specific as possible. Don't just say "the fan blows all the time". Instead, say "The outdoor fan blows all the time" Give location of what unit you are wanting help with.
Heating & Cooling Logo
How do I add freon to a royal sovereign 3012 a.c. unit. I just bought it and was told I could just add freon to in
Fergusons n other hvac supply stores sell ac parts, etc...not sure if need hvac license to buy freon, depending where you're located, but I kno can buy freon online, but still not sure if going to ask contractor/hvac # once get to purchasing screen....as to where u need to put freon in that particular model, always ask Google n guarantee somebody made a video somewhere that will pop up, giving u a tutorial on it.
1st stage of heat blows cold air
What is the model numbers of your units?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
how to turn hunter thermastat model 44134 on
This question needs to be reclassified with aftermarket programmable home thermostats--not fans.
Hunter 44134
Getting the wiring connections correct to the terminals in the back plate is essential. Understanding better which colored wires do what functions for your particular brand and model of HVAC gear proves essential, too: "That's the rub!"
Unlike the brilliant and wisely-instituted electrical code, a sensible common "code" for HVAC thermostat wires doesn't exist--each brand, and many models represented by such brands--may have their own peculiar wiring color conventions. HVAC techs also have noted the increasing numbers of brands and models in the market these days, as well--thus, they too may resort to online help threads concerning such issues. (Certainly, the wiring conventions for heat pumps differs also from that of a conventional heat/air setup.)
Unfortunately, many of Youtube's demonstrations from HVAC pros prove merely general info concerning HVAC systems--these may prove somewhat useful: Being merely general info, they're often not specific enough always for particular units, though. (This proves keenly true concerning thermostat wiring.)
Always switch off the circuit breaker for your HVAC system before proceeding with wiring. My system is a Goodman heat pump--it uses a five-wire thermostat setup: The 44134 model from Hunter doesn't feature a terminal in the back plate for the "C" wire for that. (The blue wire from my Goodman heat pump is the "Comm" or "C" wire--that's very confusing in it's own way--the "B" terminal on the back plate for the 44134, and most other programmable thermostats, often is used with B-coded wires for other manufacturers' HVAC units--generally, "B" wires for such units are blue, as well--beware of reliance upon wiring colors!)
Hunter's FAQs clearly indicate that the "C" wire connection isn't always necessary, nor appropriate, for their thermostats--their 44134 is one isn't an exception. I twisted on a small, gray wirenut onto end of my blue Comm wire, further securing that better with electrical tape. (Simply wrapping the Comm wire well with electrical tape should prove also sufficient.)
Unless you know your system's peculiar wiring very well (that is, you're likely an HVAC tech), don't try to connect a Comm wire to another terminal on the back plate for the 44134--you'll likely ruin your thermostat (perhaps along with some other HVAC electronics): You may need then to get an HVAC tech out, after all!
As indicated above, don't merely "match" wiring colors (as a woman might for interior decorating or remodeling)!: This proves a continuing and overly common, comical mistake! Prove instead somewhat skeptical of thermostat wiring colors! A Biblical scripture applies: "Be as wise as serpents!" Take your time to get wiring connections right!
I've noted that the 44134 unit relies totally upon 2 AA batteries (not supplied in the package)--those must be in good working order and oriented correctly--otherwise, your thermostat and HVAC system won't function. Furthermore, the control unit may be easily removed from the back plate--thus allowing "easy-chair" configuration--again, HVAC and fan functions will halt immediately--the connected unit proves necessary for continued function.
Hunter also points out (on their packaging as well) that the 44134 (and, many other (if not all) Hunter thermostats) won't work with baseboard heating systems. Hunter's site FAQs prove too sparse--some may prove keenly useful, nonetheless.
I can't yet get my heat pump system to work with Hunter's "always on" fan switch setting--the rightmost "Auto/On" setting for that bottom-mounted switch at the right. Perhaps a jumper wire proves necessary in the back plate terminals--somewhere. (I've noted this also for Hunter's common 44277 model, as well.) I glean perhaps that somehow invoking the "G" terminal proves necessary. As usual, investigation proves warranted.
Definitely note the "Cool, Off, Heat" switch on the bottom left of the unit: Yeah, that's all too easy to forget. The Hunter 44134 doesn't provide any feature allowing automatic switching between heating and cooling--one must choose which function for the thermostat to control. If the switch is set to "Heat," cooling isn't possible--and, vice-versa.
For reference and troubleshooting, keep the manual and install instructions in a safe, memorable, and easily accessible place. Hunter does provide PDF manual versions online--installation instructions prove lacking online though--they're not in the user manual, either. Unfortunately, Hunter doesn't upgrade it's PDF manual versions.
I glean that Honeywell units may prove generally more easily configurable than Hunter units. Nonetheless, configuring Hunter units proves far from impossible, though. Configuring Hunter thermostats prove perhaps not as "intuitive.": The formal user manuals provided by Hunter thus may prove more keenly necessary for their thermostats' configuration.
Getting personal help online from Hunter may prove somewhat difficult (that may have changed recently). A few years ago, I called customer support: A woman answered my wiring question very satisfactorily. (I noted a jumper wire connect to the terminals of my old manual thermostat--she indicated that the jumper proves unnecessary in Hunter units.) Hunter phone support hours prove somewhat limited--they're similar to traditional office hours.
As with most programmable thermostats, the Hunter is a PRC (Chinese)-fabricated general-purpose consumer circuitry device. As such, it's (overly) intended to be wired and configured by the user to provide correct function for many particular and compatible HVAC brands/models. Given the particular installation that may perhaps prove difficult. Given the general-purpose nature of such thermostats, a simple installation sheet of instructions can't always offer sufficient and correct answers.
Without the particulars of your HVAC system and thermostat wiring, it proves very difficult in some cases for Fixya and other DIY sites to provide correct answers. (Most DIYers ultimately do succeed with install and use of programmable thermostats, though.)
"Proust" thanks you for getting this far!: Perhaps some of my particular solutions here do prove useful to some of you--more nit-picking, detailed work and anecdotes (intended for specific brands and models) needs to be offered in this area....
Mar 17, 2013 • Dryers
Brand New Heat Pump Compressor fan turns on then off after only seconds.
What is the model number of the outdoor unit?
HEATER IS NOT BLOWING HEAT ONLY BLOWS COOL AIR. ITS A GOODMAN UNIT ARUF036-00A-1A. WHAT ARE SOME OF THE MOST PARTS TO MALFUNCTION IN THIS UNIT?
Electric heat strips, Fuse Link, Sequencers, main limit.
As always, if you are in doubt about what to do, the best advice anyone should give you is to call a licensed electrician or HVAC tech to advise what work is needed.
Before you do any work yourself,
on electrical circuits, equipment or appliances,
always use a test meter to ensure the circuit is, in fact, de-energized.
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
