Tip & How-To about Medical
Five steps for brush your teeth perfectly
Aim the toothbrush at a forty five degree attitude towards the gum line.
Use a pea-sized quantity of toothpaste.
Use a gentle round motion.
Repeat on the interior surfaces.
Use a mild backward and forward motion at the chewing surfaces.
Spit out the toothpaste after brushing.
You do not need to rinse, as the small quantity of fluoridated toothpaste left to your mouth after spitting maintains to defend in opposition to enamel decay.
Medical Logo
2answers
My samsung refrigerator model RF266AEPN refrigerator compartment won t go above 50 degrees
I think if you check fridges are made to run fifty or below. Ours runs at forty five degrees.
2answers
Do electric toothbrushes require a different amount of toothpaste compared than manual toothbrushes?
No, you should put the same amount of toothpaste on all types of toothbrushes. You should put enough so you can clean your teeth well.
2answers
The CD player doesn't always work. It cuts on and off at times. What should I do?
check and make sure the CD's aren't scratched. If they are scratched use toothpaste to clean it by,
1.put 3 or 4 pea-sized dots of toothpaste around the cd.
2.take some kind of cloth or tissue paper to rub the toothpaste
3.rub from the middle to the outside, ACROSS the circular path (if you're not rubbing in this direction, you're not doing any good)
4.and wash off the toothpaste and any tissue follicles that got attached to the cd, throw the tissue/cloth out
5.-dry the cd on a clean towel
if this doesnt work take try blowing into the cd player, their may be a build up of dust.
Top Medical Experts
Don A
Don A
ADMIN Canada
ADMIN Canada
Are you a Medical Expert? Answer questions, earn points and help others
