Tip & How-To about Coffee Makers & Espresso Machines
Fix Drip in Steam Wand for Starbucks Saeco Barista
To fix a dripping steam wand:
First empty the water tray and unplug the unit. Then remove the six metal tapping screws from back of unit. The back lifts off as there is a flange at the top to hold on the metal cover. For some reason, the bottom two screws have lock washers.
On the steam wand there is a recessed set screw that may be removed with an Allen wrench to open the steam wand. The steam wand stem twists out. Inside and stuck in the unit rather than the stem is a pin with a white plastic washer on it. I removed that, cleaned out the unit and the plastic washer. I found that q-tips worked best. I then reassembled after cleaning various parts. Watch the flange when putting the metal cover onto the back of the unit.
Voila! No drip.
Coffee Makers & Espresso Machines Logo
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
Delonghi Magnifica My steam arm drips when I make coffee.
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
My machine blinking on steam, the wand does not want t o steam, the espresso does not pour. The knob is turned on stand by , but still some steaming noise comes, but no steam comes from the wand, nor liquid from the portafilter. I used the machine only 1o days, first day today I pour beans in a grinder and this happened. I try to cool it off, unplugged it from the outlet, empty the grinder, switched to steam, readjust the filter...nothing happens
When it is blinking on steam it means it is preparing the unit for steam. When the steam light goes solid your unit is ready to make steam.
  • Turn from standby to steam then wait for steam light to go solid.
  • When solid steam wand will begin dribbling then spitting out water, which will then turn to steam.
  • When it begins to steam, turn back to standby. NOTE: you only have 6 seconds before steaming turns off.
  • place steaming wand in jug and turn from standby back to steam.
You will hear pumping noises when you turn off your steam, because it releases the steam and puts the excess water in to the drip tray.
  • make sure your bean hopper is properly locked in to the unit. Grinder won't work if hopper not locked in.
  • Make sure your water filter has been prepped and locked securely in to the reservoir and your reservoir is filled.
  • Use fresh beans.
  • Sounds funny but use good quality water, do not use ordinary tap water. Make sure it is filtered or use bottled water (cooler bottles).
  • Try to grind your beans to a good consistancy.
  • Breville recomends about 10kg tamping pressure, use a set of scales to check the feel.
  • Tamp to about 3-5 mm below rim of grouphead (portafilter). Or the tamp has a guide on the side, that silver side on the tamp is the tamp line. Pretty vauge about that in the book.
If all else fails go to www.breville.com.au and check your model and watch some of the vid clips.
Jan 06, 2011 | Breville Fresca BES860 2Cup Coffee Maker
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a pumping sound. When I push button 27 (or 26) for hot water, no hot water comes from the wand, but hot water goes into the drip tray. Help. Thanks!. Is this correct: Yes
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Water Is Dripping out a valve on the bottom of Silvia.
Hi ChicagOkie
If we're thinking about the same thing, then yes you're correct in saying this is a pressure release valve. It is perfectly normal for it to drip every time you make a shot. It should, however, drain into the stainless steel tray along with any drips from the steam wand or the filter group. The base that the tray sits in does have a hole in it under the release valve, which I think is for people who may have the machine set up on a drainer so the tray doesn't need emptying. You can also get water under the machine if you direct the steam wand towards the tray as it will force any liquid collected in the tray to shoot over the sides and out the underneath.
HTH
Nick
Nov 07, 2007 | Rancilio Silvia Espresso Machine
Top Coffee Makers & Espresso Machines Experts
Ross Keen
john h
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
