Tip & How-To about Exercise & Fitness
How to change the battery in a Kettler Astro cross trainer
The cross trainer takes two AA batteries which are in a compartment behind the display. To replace them, remove the large screw on the underneath of the cross trainer behind the display and the display will lift out easily. The battery compartment is on the back and after replacing the batteries and the compartment cover, put the display back into its slot and screw it back in.
Exercise & Fitness Logo
Replacement batteries for Schwinn Airdyne AD3?
It should just be 2 AA batteries. Remove the battery door on the back of the computer to expose the batteries. Remove and replace. Computer Graphite Airdyne Big Fan Schwinn 92823 SPORTSMITH net
May 16, 2014 | Schwinn 430 Elliptical Trainer
how do I repair my kettler condor cross trainer
What's wrong, is the readout simply not working? If thats all it's the battery, which is easy to replace but a little harder to find. Just in case it's the battery I'll paste here my solution:
If you look behind the unit, (directly behind the digital readout) you'll see a small rectangular inset, if you look up in that (I used my cell phone light), you'll see a tab that you can pry with a screwdriver gently to release the computer section. Just keep one hand on top, when you pry it you'll feel the unit pop up, then you can lift it out. It takes 2 AA batteries, thankfully not some bizarre disk batteries :)
Btw when you look at the readout, you'll notice it's set in a silver square- that square is the computer module that pops out.
Hope this helps!
Feb 09, 2011 | Exercise & Fitness
how do i change a battery?
Look for a tiny cross head screw then look for a small cross head screwdriver! ;-)
That will open a compartment that you need to put 2 AA batteries in.
Don't open the triangular screws - you will have tiny cog wheels all over the floor!
Dec 23, 2009 | Brio Polar Express Battery Engine
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
