Tip & How-To about Electronics - Others
What Things to Consider Before Buying a Toner Cartridge?
If you are planning to buy a new toner cartridge, then you should always keep many different things in mind. You cannot just buy any cartridge without determining certain factors. There are many different kinds of toners that you can buy, such as cf283a and others.
These factors are essential for the proper functioning and longevity of the printer and the toner. The things that you should consider while buying a toner cartridge is as follows:
The Brand of the Toner
This is the first thing that you would have to keep in mind while buying a toner. The model and the brand of the toner are very important as it should match with the printer.
Moreover, it is never a wise decision to invest in cheap toners. You can buy cf283a or other HP toners which are popular in the market for their high performance. You should also use the same model of the toner continuously unless it is not working well. Keep the model number so that you can buy it when the toner finishes.
The Type of Toner
Different types of toners are present in the market, such as OEM, compatible, and remanufactured. There are also differences in the price of these cartridges. After you have chosen the model of the cartridge, choose the type of cartridge that would be effective for your printer.
The Page Yield of the Toner
This is a very important thing that you would have to consider. You would have to see the number of pages that the toner would be able to print. By determining this, you would be able to decide which toner you will buy for yourself.
These are some of the things that you should keep in mind when you are buying any toner such as the cf283a or any other model.
Electronics - Others Logo
replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Need to replace toner. Do I buy a whole new toner cartridge or just toner and if just toner, how do I put the liquid in? Thank you
It is always better to buy a whole new toner cartridge than to deal with the mess of trying to refill the old one. So therefore as a technician I would recommend you buy a whole new toner cartridge.
Aug 24, 2010 | Canon PC1061 Copier
what is toner resetting by software or hardware?
A hardware module is used to reset clp 315 permanently after that you can use refill toner forver. www.nakshatraworld.com
Jan 25, 2010 | Samsung CLP 315 Laser Printer
Just refilled a nearly new Brother DR2000 and
Who knows what you did wrong? - maybe nothing. But one of the following is the most likely reason:
- You simply topped up the cartridge with toner without completely emptying the the remaining toner out. There is always toner left-over inside, and different brands don't mix well.
- You used a brand of toner not designed for that cartridge.
- It's simply a crappy compatible brand - I've run across all kinds. All toner IS NOT created equal.
Jun 08, 2009 | Ricoh FT3713 Copier
Top Electronics - Others Experts
Tom Chichester
Bill Boyd
Are you an Electronics - Other Expert? Answer questions, earn points and help others
