Tip & How-To about Refrigerators
Uses for a Small Refrigerator
If you are in the market for a new refrigerator, know that you do not necessarily have to go with the typical standard size. If you live alone, have little extra space, or just need an extra fridge to add to your regular one, you can benefit from a small refrigerator. Find out the many uses for such an appliance.
Many people assume that just because they have the space available, they need to purchase a full size fridge. However, most people who live alone do not use the same amount of space for their food that a family does, which means that much of the refrigerated area is wasted. This can cause electricity bills that are higher than they need to be. Rather than pay the upfront cost for a regular sized fridge, and then pay for the electricity usage every month thereafter, consider purchasing a small refrigerator. You can choose from several sizes, all of which are less than 20 cubic feet, which is the minimum that most families have. You can always upgrade later if you need to, and use the small refrigerator as an extra appliance.
Some people only have limited space in their house. Perhaps you live in a dorm or small apartment with a cramped kitchen. Filling a small residence with a large fridge does not usually make sense, especially if you live alone or with one roommate. If this is the case for you, consider small refrigerators. Most dorm rooms look great with a fridge that is anywhere from two to five cubic feet. Of course, you can purchase a larger one if it is needed, but most people in small residences find this to be the perfect size. An apartment with a small kitchen may be better off with a fridge that is under the traditional 20 cubic feet, as this can hold a lot of food without taking over the entire room.
If you already have a good sized kitchen fridge and just want an extra, a small refrigerator can be great for storing drinks and snacks that need to be kept refrigerated. You can keep it in your home office, den, or bedroom. Note that many small refrigerators fit perfectly under desks and counters, so figure out whether you want to do this before buying a fridge so that you can measure the space you have. Keeping a small refrigerator somewhere other than your kitchen can help you and guests be as comfortable as possible, with constant access to cold beverages.
Go to my site: https://instituteofkitchenscience.com/
Refrigerators Logo
how to se what year model my vmax is from
Check your frame for your serial number. Where I live the date of manufacture must appear near the serial number of the vehicle. This plate or label typically on the neck of the frame, near the front, where the handle bar is attached. Where I live, this date of manufacture is not necessarily the the model year.
You could also check your owner manual, typically found in a small compartment behind the side cover on the left hand side.
You could check your vehicle ownership paper also. Since this is not typically an off road vehicle, there must be some registration paper associated with the ownership. Where I live, every vehicle has such a document. It may be different where you live ... just saying ...you should be able to get this information from a variety of sources immediately available to you.
By the way, this bike was introduced in 2005 so it is not likely it was manufactured prior to 2004 if that is of any help to you.
Thanks for your interest in FixYa.com
Mar 10, 2013 | Motorcycles
personal computer, need to know the size of the hard drive
it is 3.5inch hard drive fits in the bay just like the floppy drive size
Dec 04, 2010 | Computers & Internet
Refrigerator gfci question.
not necessary to have a gfci on these anymore with the polarized ground plugs on them and the plastics in use there isn't much if any contact with any metallic surfaces on them anymore
May 24, 2010 | Haier White 2.7 Cu. Ft....
Can we retrofit our 20 year old KitchenAid Superba Refrigerator
Refrigerator efficiency is dependant on multiple things...
compressor efficiency
Refrigerant used
Size/type of evaporator
Size/type of condensor
Ambient temperature
Insulation used and thickness of
There have been some advances in compressor efficiency in the last twenty years but if your unit is using R-12 it would most likely have to be upgraded to R134a due to environmental regulations. Therefore, without a major redesign of your unit to include resizing the system and somehow adding insulation, updating to the newest and greatest compressor will really not gain you much in efficiency and cost as much or more than an entire new unit.
There are still units made without stainless. Unless your unit is a power hungry monster (and yours is not) I doubt a new unit would save you more than a buck a month in power savings.
I wish I could make a recommendation for you but I do not know the market well enough. I know if I were in your place I would hang on to my unit for as long as it works well and continue to save up for a higher end model (with the best warranty/service plan) and look ofr the best replacement out there.
Note: Beware of high end units that are just high priced due to looks. Most units these days are made from the lowest bidder parts (world-wide) and even if they look awsome and have high quality standards during production are subject to the "roll of the dice" due to the cheap electronics used for controls.
Good-luck, Subdriver
Apr 04, 2010 | KitchenAid Superba 21.6 cu. ft. Top...
76 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
