Tip & How-To about Electronics - Others
How to repair Motorolla Talkabout 250 antenna
I have just repaired four of these radios, with complete success.
You need a tube of black Stixall (currently £5.81 from Tool Station), a skeleton gun and a saucer of water with a good squirt of washing up liquid.
Take the back off the radio, take out the batteries and remove the rear cover by undoing the retaining screws using a screwdriver with a star shaped bit. Unscrew the circuit board now exposed using the same screwdriver bit. Remove the damaged rubber aerial with coiled copper core, being careful not to damage or distort the copper core. It lifts off one of the screw lugs revealed when removing the circuit board. Get rid of all of the old rubber.
Now put the end of the copper coil back over the lug (where it came from) and screw the PCB back on followed by the back of the unit.
Now form a new rubber cover to the copper aerial using Stixall, squirted into place. Squirt it down into the aerial housing so that it will get mechanical purchase from the body of the radio. Put on plenty, completely coating the copper aerial. Now dip your fingers in the saucer so that they don't bond to the Stixall and mold it into a smooth aerial shape. Leave it to cure for 24 hrs and then dust it with flour. Job done.
I have tested my repaired radios and they are great, the new "aerials" have lasted well. I am especially pleased that I don't have to throw them away.
Good luck - regards SJP
Electronics - Others Logo
Does a 2004 Pontiac Montana's radio have an amplifier? If it does, where would it be???
Unless the face of the stereo says MONSOON there is no separate amplifier. On a Non-Monsoon Delco system all four amplifiers are built into the stereo, Left front, Right front, Left rear, and Right rear. Monsoon systems do have a separate amplifier which basically boosts the output of the four regular amps in the radio. I can't imagine all four of those amplifier output chips going out at the exact same time. I would pull the stereo and check if all plugs are seated properly. If those were all securely plugged in I would (myself) inspect the inside of the unit for the cause of failure. For example all four amp chips pull power from a common point and if one chip had a severe enough short in it, this may have caused the power feed trace on a circuit board to overload (too much current going through it) and created an open which killed power to all four of them. Any good electronics repair shop worth their salt should be able to repair it if you can locate one willing to try. It may only need a circuit board trace repair and one amp chip replaced.
Mar 07, 2015 | 2004 Pontiac Montana
what is the traffic button for in a 2002 alero
According to the owners manual
TRAF (Traffic): Press this button to receive traffic announcements. The traffic announcement brackets will appear on the display. TRAF will appear on the display if the current station broadcasts traffic announcements. If the current station does not broadcast traffic announcements, the radio will seek to a station that does. When the radio finds a station that broadcasts traffic announcements, it will stop. If no station is found, NO TRAFFIC will appear on the display. When a traffic announcement comes on the current radio station or a related network station, you will hear it, even if the volume is muted or a compact disc is playing. If the compact disc player was being used, the compact disc will stay in the player and resume play at the point where it stopped. INFO (Information): If the current station has a message, INFO will appear on the display. Press this button to see the message. If the whole message does not appear on the display, parts of the message will appear every three seconds until the message is completed. To see the parts of the message faster than every three seconds, press this button again. A new group of words will appear on the display. Once the complete message has been displayed, INFO will disappear from the display until another new message is received. Hope this helps.
Feb 25, 2014 | 2002 Oldsmobile Alero
i need to find cheats codes for red bricks in lego marvel superheroes
i really hope this helps
Cheat mode:
Pause the game, select the "Extras" option, and choose the "Enter Code" selection. Then, enter one of the following codes to activate the corresponding cheat function:
Result Code Extras 2x Stud Multiplier UZFBG4 Vehicles Avenging Cycle 5T3CQU Pumpkin Chopper 35E41W SHIELD Staff Car D5B7O3 Spider Bike SH9MZQ Characters Beetle Black Cat P9OWL0 Captain America (Classic) 7HWU4L Carnage AA0Z50 Howard The Duck J58RSS Hydra Soldier B7AA3K Iron Man (Mark 17 - "Heart Breaker") 2NGSRZ Iron Man (Mark 38 - "Hulkbuster") CK7SDS Iron Patriot MODOK SZ8Q06 Spider-Man (Future Foundation) WFOZXQ Thor (Classic) H8CSE6 War Machine TQ4C57 Wolverine (with hood "cowl") OAW2LB
  • Bonus charactersSuccessfully complete the indicated task to unlock the corresponding character:
      A.I.M. Agent: Successfully complete Level 10: "That Sinking Feeling". Abomination: Successfully complete Level 4: "Rock Up At The Lock up". Agent Coulson: Successfully complete the "Tabloid Tidy UP" bonus level. Aldrich Killian: Successfully complete Level 5: "Rebooted, Resuited". Ant-Man: Collect the Ant-Man token in the Industrial District. Archangel: Collect the Archangel token south of the X-Mansion (south of giant billboard). Arnim Zola: Successfully complete Level 6: "Red Head Detention". Beast: Successfully complete Level 8: "Juggernauts And Crosses". Beetle: Collect the Beetle token at one block east of the Central Park lake. Black Cat: Collect the Black Cat token at the cat pet shop, directly under Lady Liberty on the map; requires Spider-Man. Black Widow: Successfully complete Level 3: "Exploratory Laboratory". Blob: Collect the Blob token after completing the "Put Up Your Dukes" bonus level. Captain America: Successfully complete Level 2: "Times Square Off". Captain America (Comics): Successfully complete "The Brick Apple" bonus level. Captain Britain: Successfully complete "The Brick Apple" bonus level. Colossus: Collect the Colossus token at the front right courtyard of the X-Mansion. Cyclops: Successfully complete Level 8: "Juggernauts And Crosses". Damage Control: Collect the Damage Control token by putting out fires on the S.H.I.E.L.D. Helicarrier deck with the water gun. Deadpool: Collect all Deadpool Red Bricks. Doc Ock: Successfully complete Level 2: "Times Square Off". Doc Ock (Ultimate): Successfully complete the "Tabloid Tidy UP" bonus level. Doombot: Successfully complete Level 9: "Doctor In The House". Drax The Destroyer: Successfully complete Story mode, then complete three missions received from Drax. Electro: Successfully complete the "A Shock Withdrawal" bonus level. Frost Giant: Successfully complete Level 7: "Bifrosty Reception". Galactus (Playable): Successfully complete Level 15: "The Good, The Bad And The Hungry". Gambit: Successfully complete three of Gambit's missions". Gamora: Successfully complete Story mode, then complete the first missions received from Drax. Green Goblin: Successfully complete Level 9: "Doctor In The House". Groot: Successfully complete Story mode, then complete three missions received from Groot. H.E.R.B.I.E.: Successfully complete Level 2: "Times Square Off". Hawkeye: Successfully complete Level 3: "Exploratory Laboratory". Howard the Duck: Successfully complete the "Nuff Said" bonus level. Hulk: Successfully complete Level 1: "Sand Central Station". Human Torch: Successfully complete Level 6: "Red Head Detention". Iceman: Successfully complete Level 8: "Juggernauts And Crosses". Invisible Woman: Successfully complete Level 9: "Doctor In The House". Iron Fist: Successfully complete the race mission with Blade, then win the fight with the ice enemies in the Blade mission. Iron Man (Heroic Age): Successfully complete Deadpool's "New York Event" bonus mission. Iron Man (Hulkbuster): Land on the "S" sign landing platform, then destroy all air vents around the "S" sign. Iron Man MK I: Successfully complete Level 5: "Rebooted, Resuited". Iron Man MK VI: Successfully complete Level 1: "Sand Central Station". Iron Man MK VII: Successfully complete the "House Party Protocol" bonus level. Iron Man MK XLVII: Successfully complete Level 5: "Rebooted, Resuited". Iron Man MK XVII: Successfully complete the "House Party Protocol" bonus level. Jean Grey: Successfully complete Level 8: "Juggernauts And Crosses". Juggernaut: Successfully complete Level 8: "Juggernauts And Crosses". Kraven The Hunter: Collect the Kraven token by shooting the five targets next to the Godzilla-type icon at Central Park. Loki: Successfully complete Level 15: "The Good, The Bad And The Hungry". M.O.D.O.K.: Successfully complete Level 10: "That Sinking Feeling". Magneto: Successfully complete Level 13: "Magnetic Personality". Maria Hill: Successfully complete Maria Hill's three missions on the Helicarrier. Mister Fantastic: Successfully complete Level 2: "Times Square Off". Mysterio: Successfully complete the "Thrill Of The Chess" bonus level. Mystique: Successfully complete Level 12: "Rapturous Rise". Nick Fury: Successfully complete Level 9: "Doctor In The House". Nova: Successfully complete the foot race mission with Nova to the east of the Godzilla-type icon at Central Park. Professor Xavier: Successfully complete Professor Xavier's three missions behind the X-Mansion. Psylocke: Successfully complete all Captain Britain's missions. Pyro: Successfully complete Level 8: "Juggernauts And Crosses". Red Skull: Successfully complete Level 6: "Red Head Detention". Rhino: Successfully complete Level 12: "Rapturous Rise". Rocket Raccoon: Successfully complete the following three missions: Garbage truck northwest of Central Park, just east of the "Feeling Fisky" bonus mission, and three or four blocks south of the east coast. Ronan the Accuser: Collect the Ronan character token by finding the hidden path behind the statue south of his icon. Sandman: Successfully complete Level 1: "Sand Central Station". Silver Surfer: Successfully complete three Silver Surfer missions. Spider-Man: Successfully complete Level 1: "Sand Central Station". Spider-Woman: Collect the Spider-Woman token west of the park, on the southern-most part of the island. Squirrel Girl: Collect the Squirrel Girl token on the docks, northwest of the "Put Up Your Dukes" bonus mission. Stan Lee: Rescue all 50 Stan Lees. Star-Lord: Successfully complete three missions from Star-Lord. Storm: Successfully complete Level 8: "Juggernauts And Crosses". Symbiote Scientist: Successfully complete Level 3: "Exploratory Laboratory". The Destroyer (Playable): Successfully complete Level 7: "Bifrosty Reception". The Mandarin: Successfully complete Level 5: "Rebooted, Resuited". Thing: Successfully complete Level 9: "Doctor In The House". Thor: Successfully complete Level 7: "Bifrosty Reception". Tony Stark: Successfully complete Level 5: "Rebooted, Resuited". Tony Stark (Underwear): Successfully complete Level 4: "Rock Up At The Lock Up". Union Jack: Successfully complete "The Brick Apple" bonus level. Venom: Successfully complete Level 3: "Exploratory Laboratory". Wasp: Collect the Wasp token one block south of the Oscorp Building. Wolverine: Successfully complete Level 4: "Rock Up At The Lock Up".
  • Jan 01, 2014 | Video Game Consoles & Games
    i have a sony kp-61v90 projector tv and the colors are making the red stick out, feels like a 3d, any help?i kalld a tv repair which charged me $50 and said to repair $350 which is pretty crazy....help
    i'm assuming that your complaint is the red is predominant over the other colors- if it is a rear projection set, there are three tubes [r,b,g], and each one has its own flyback with a focus and 'g2' control on it. try backing down the red g2, and if the picture is too dark, turn down the color control [so you should have a black and white pic], then adjust the g2 controls until you have a satisfactory black and white pic- after that, when you turn the color back up, you should have a good pic. sometimes. adjusting the g2 can affect the focus, and there is a focus control on the flyback. there are also optical focus [moveable lenses] on each tube, but they are primarilly for initial setup of the set, and should never have to be adjusted, unless the tube has been replaced. fyi- i happen to have a complete set of sony rear projection tubes [r,b,g] complete with lenses and neck coils i am currently trying to sell, but it doesn't sound like you need tubes at this time, but it's something to keep in mind, because these tubes are becoming extremely rare and hard to find, and cost upwards of close to a thousand dollars a piece, i'm selling the complete set for four hundred dollars. good luck!
    Sep 05, 2009 | Sony KP-61V90 61" Rear Projection...
    wireing turner plus 3 to president washington that is four pin
    Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
    Jul 23, 2009 | Magnum DeltaForce CB Radio
    377 people viewed this tip
    Top Electronics - Others Experts
    Marvin
    Marvin
    Tom Chichester
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
