Tip & How-To about Electrical Supplies
Repair broken power cord
I have a 50-ft power cord for my electric pole saw. In an accident, the saw cut the power cord. It's long cable and I want to save it. My method keeps the cable lean and retain it's strength. It's not water-proof, but I never use a pole saw in a rainy day.
Electrical Supplies Logo
2answers
How do I pick the perfect pole saw?
Want to saw up high, but think it's dangerous to saw on a ladder? Good thinking. So how can you get your saw to reach those high branches while keeping your feet planted on the ground?
Take a lightweight chainsaw, add a stick, and you get a pole saw.
TYPE There are three types of pole saw. You can choose any one of them based on your requirements.
CORDLESS POLE SAW Cordless pole saws are said to be the handiest pole saw as it removes the hassle of carrying wires and cords during pruning. It operates through a rechargeable battery. But, due to its battery pack, its operation time is very specific. If you want to extend the time for heavy duties, you can use extra battery packs.
One of the best advantages of cordless pole saw is its need for low-maintenance. You would hardly need to maintain its well-being.
GAS POWERED POLE SAW Gas powered pole saws are mostly chosen by the professionals for its heavy-duty bars and chains and have the power to cut huge and large branches with ease. This pole saw can be extended up to 9 inches so you might distinguish its expertise in trimming high rise trees. It is good for regular use. It is heavier than the electric one and noisy also. Despite being heavy, you would not face any problem working with it as the pole saw is easy to balance.
ELECTRIC POLE SAW Electric pole saws are preferred for small branches trimming as it has blades of 6"-10". It weighs about 10 pounds that means you can carry the saw effortlessly. It does not require high maintenance as well. Plug the long extension cord before you start, aim at the branches and begin pruning with this electric pole saw.
More details
Guide on How to Pick the Perfect Pole Saw
Apr 16, 2018 • Garden
108526-1 pole saw
I bought this chain without first examining the "count" of my old chain. I found this new chain had 39 drive-links while my OLD chain had 40 links. My 10" Remington saw had enough chain-tensioning adjustment to compensate for that missing link and this new 39-link chain runs fine... cuts very well. Happy.
more details Pole Saw
electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
2answers
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Top Electrical Supplies Experts
john h
Robert Wooley
Robert Wooley
Are you an Electrical Supply Expert? Answer questions, earn points and help others
