Tip & How-To about Home
Install the gas cooler
How to install an electric air conditioner and its electronic instruments, which includes a fuse of a fuse type, as well as a standard cable?
Home Logo
where is the body control mod. on a 2000 excursion?
Generic Electronic Module (GEM)-Generic Electronic/Central Timer (GEM/CTM) Removal
NOTE: The GEM must be reconfigured upon replacement. Refer to the scan tool help screen on the Ford Service Function (FSF) card to program tire size and axle ratio.
  1. CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.Disconnect the battery ground cable. For additional information, refer to Section 414-01.
  1. CAUTION: Use care when removing the instrument panel steering column cover (044F08) or damage to the cover locating tab may occur.Remove the instrument panel steering column cover.
    1. Unlock the retainers.
    1. Remove the instrument panel steering column cover.
  1. Disconnect the bulkhead connectors from the instrument panel fuse junction panel.
    1. Loosen the bolts.
    1. Disconnect the bulkhead connectors.
  1. Position the instrument panel fuse junction panel aside.
    1. Remove the nuts.
    1. Remove the bolts.
  1. Remove the generic electronic module/central timer module (GEM/CTM).
    1. Disconnect the electrical connectors.
    1. Remove the screws.
    1. Remove the GEM/CTM.
  1. To install, reverse the removal procedure.
I believe ford calls it a gem module.
Jan 23, 2018 | Cars & Trucks
what cause 3 amp fuse to keep blowing when power in turn on goodman 16 sier air handler
Hello...
Apparently, there is an overload or shorted wires. Elequipo Disconnect electricity and check the cables are in good condition.
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
how do i remove dashboard clocks
Do not leave the instrument cluster face down for any length of time. Lower and extend the steering column to its maximum rearward position. Disconnect the battery ground cable. Remove the air vent. Release the tangs. Remove the air vent. Remove the air vent. Release the tangs. Remove the air vent. Remove the center air vents. Release the tangs. Remove the center air vents. Detach the switch assembly. Remove the switch assembly. Disconnect the electrical connector. Remove the instrument panel veneer trim retaining screw. Remove the instrument panel veneer trim retaining screws. Remove the instrument panel veneer trim retaining screws. Detach the instrument panel veneer trim. Remove the instrument panel veneer trim. Detach the instrument cluster. Remove the instrument cluster. Disconnect the electrical connectors. To install, reverse the removal procedure.
Jul 28, 2009 | 2002 Jaguar X-Type
A/C evaporator overhaul on a Lincoln Continental 1999
SECTION 412-03: Air Conditioning 1999 Continental Workshop Manual REMOVAL AND INSTALLATION Evaporator Core Removal
NOTE: The evaporator core is serviced as a core and housing assembly. The evaporator core, internal doors, seals and door linkage are included with the housing. Transfer the blower motor and wheel assembly, heater core and cover, dash panel seals and vacuum actuators to the new housing.
  1. Remove the rear seat airflow duct (18C420). For additional information, refer to Section 412-01 .
  1. Remove the instrument panel (04320). For additional information, refer to Section 501-12 .
Instrument Panel Removal
sxe~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
  1. Remove the passenger side air bag module. For additional information, refer to Section 501-20B .
  1. If equipped, remove the floor console; refer to Console—Floor .
  1. If equipped, remove the mini console; refer to Console—Mini .
  1. If equipped, remove the rear seat climate control air duct sleeve.
  1. Remove the steering column; refer to Section 211-04 .
  1. Release the cable from the parking brake actuator.
    1. Release the cable conduit from the parking brake actuator.
  1. Disconnect the LH outboard bulkhead electrical connector.
    1. Loosen the bolt.
    1. Disconnect the LH bulkhead electrical connector.
  1. Disconnect the LH inboard bulkhead electrical connector.
    1. Loosen the bolt.
  1. If equipped, disconnect the heated seat switch electrical connectors.
  1. Remove the steering column mounting support to instrument cowl brace bolts.
  1. Remove the instrument panel dash brace to instrument panel bolt.
  1. Position the instrument panel dash brace aside.
    1. Loosen the nut.
  1. Remove the RH instrument panel insulator (046A24).
    1. Remove the pin-type retainers.
    1. Remove the RH instrument panel insulator.
      • Remove the courtesy lamp.
  1. Disconnect the vacuum harness connector.
  1. Disconnect the in-line electrical harness connector.
  1. Position the RH scuff plate aside.
  1. Remove the RH cowl trim panel.
  1. Disconnect the antenna in-line connector.
  1. Remove the ignition/shifter interlock cable from the bracket and the shifter interlock cam.
  1. Remove the instrument panel defroster opening grille assembly.
    1. Lift upward to release the instrument panel defroster opening grille assembly from the instrument panel.
    1. Disconnect the two electrical connectors (one each side).
  1. Remove the instrument panel cowl top screws.
  1. Remove the RH instrument panel support to cowl side nut.
  1. Remove the LH instrument panel support to cowl side bolts.
  1. Loosen the LH instrument panel support to cowl side captive bolt.
  1. Position the instrument panel away from the cowl.
    • Disconnect the electronic air temperature control (EATC) hose from the heater plenum.
  1. NOTE: Two technicians are required to carry out this step.
    NOTE: Check the cowl top clips for damage, looseness, or stripped fasteners.
  1. Drain the coolant from the radiator so that the coolant level is below the heater core (18476). For additional information, refer to Section 303-03 .
  1. Recover the refrigerant. For additional information, refer to Section 412-00 .
  1. Loosen the screw and disconnect the electrical connector from the powertrain control module (PCM) (12A650).
  1. Disconnect the heater water hoses (18472) from the heater core.
  1. Disconnect the vacuum supply hose.
  1. Disconnect the condenser to evaporator tube and the evaporator to accumulator tube spring lock couplings from the A/C evaporator core (19860). For additional information, refer to Section 412-00 .
  1. Disconnect the evaporator housing electrical connectors.
  1. Remove the nuts and the washers at the cowl panel.
  1. Remove the screws and the A/C evaporator housing.
  1. Remove the screws and the metal cover.
  1. Remove the screws and the A/C electronic blend door actuator.
  1. Remove the A/C air intake flue damper assist spring (19917).
  1. sxe~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not attempt to bend any part of the A/C damper door shaft (19A580). It is brittle and will break.
    Depress the locking ramp and remove the A/C damper door shaft from the air temperature control door shaft.
  1. sxe~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not attempt to bend any part of the lever. It is brittle and will break.
    Remove the A/C evaporator case outlet door shaft (19B752).
  1. Remove the A/C tube dash panel seal (19B588) and the A/C evaporator drain tube seal (19B739).
Apr 25, 2009 | 1999 Lincoln Town Car
I need installation directions for installation of a gem module
here it is but you must have it configured.
Generic Electronic Module (GEM) —Generic Electronic/Central Timer (GEM/CTM) Removal
  1. syo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
    Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  2. syo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the instrument panel steering column cover (044F08) or damage to the cover locating tab may occur.
  3. Disconnect the bulkhead connectors from the instrument panel fuse junction panel.
  4. Position the instrument panel fuse junction panel aside.
  5. Remove the nuts.
  6. Remove the bolts.
  7. Remove the generic electronic module/central timer module (GEM/CTM).
Feb 20, 2009 | 2000 Ford F250 Super Duty Crew Cabs
102 people viewed this tip
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
