Unplug the power card pressed menu button and then plug ?? in power cord till display showing matance mode.. After that release menu button use up and down key use up 8 press ok then also use up key press 0 and then use mono button and got purge count use up and down keys press 4 ok 8 ok 2 ok 3 ok purge count 0000 then off and on peinter and enjoy
1 power on the printer
2.press menu, mono, menu
3 press arrow up or arrow down look number 8 then press ok
4.press arrow up or arrow down look number 0 then press ok
5.press arrow up or arrow down PURGE Counter then press 2783
6.press 99 to exit maintenance mode or unplug the machine
7.turn back on the printer
Hi Ok try this it may work. 1.Go Menu Type in *2864 Type in 10 Code WSW00 shows Type in 51 Code WSW51 0000001 will show Try different values, eg change to 000000 or 0000010 BUT remember original code to get back to To exit type 99 Also can try. Solution: ·Machine off ·Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode. ·Press 80 ·Press the “mono start” button several times until you see “purge: xxxx” ·Press “2783” in order to reset the purge counter. You will see: “purge:0000” ·Press the "stop" button. ·Press “99” to exit the maintenance mode. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks ·
Hi Ok try this it may work. 1.Go Menu Type in *2864 Type in 10 Code WSW00 shows Type in 51 Code WSW51 0000001 will show Try different values, eg change to 000000 or 0000010 BUT remember original code to get back to To exit type 99 Also can try. Solution: ·Machine off ·Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode. ·Press 80 ·Press the “mono start” button several times until you see “purge: xxxx” ·Press “2783” in order to reset the purge counter. You will see: “purge:0000” ·Press the "stop" button. ·Press “99” to exit the maintenance mode. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one Hope it will work for you.
