Tip & How-To about Electrical Supplies
Choosing a suitable AC-DC power pack
Power-packs, aka AC-DC converters or wall warts step mains AC voltage down to a lower voltage, then rectify this to direct current (DC), regulate and smooth the output voltage level and ripple. Some supplies have an optional output voltage selector to match the device being fed. Unless your device is under a warranty clause that disallows usage of a non-OEM supply, a faulty power-pack can often be replaced with a suitable generic equivalent.
[1] Mains input must match your country
[2] Ensure output voltage is DC (for DC appliance)
[3] Voltage output must match appliance (eg 12V DC)
[4] PSU Amperage should match appliance rating
(never use a PSU A that is too 'light').
PSU should also not be overly high, as voltage may not drop enough to correct level when loaded.
[5] Polarity (+) and (-) must be correct (see *).
[6] For electronic / digital devices, use a good quality PSU (Power Supply Unit) ie Wall Wart..
[7] When used continuously or for long periods, the enclosed "brick" type power pack may get quite hot.
Allow enough ventilation around the pack so that the casing can be air-cooled, and add a miniature computer fan (separately supplied) if necessary, to blow air over the casing.
The attached image shows a detailed explanation.
Electrical Supplies Logo
2answers
what is the purpose of the rectifier
it converts Tesla to Edison.
AC to DC,
Jan 15, 2020 • Motorcycles
jawa 90 roadster motorcycle charging panel with battery fitted
diodes do not regulate charge
simply put diodes are one way valves for electricity and are used to rectify alternating current (AC) to direct current(DC)
you use a voltage regulator after a rectifier pack to control the voltage from an alternator of maintain a max voltage of 14.5 volts dc
take it to an accredited bike electrician
2answers
wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
2answers
how do iknow if my voltage regulator is bad on my 1993 yamaha fzr 600
hi normaly replacing it with another 1 is sometimes the only way to tell, even when tested some electrical items *** up as testing ok, and when you replace them the fault is cured, what is the fault you are getting? is your machine fitted with a seperate voltage regulator, most machines have a regulator rectifier combined, the rectifier converts alternating current ac to direct current dc, where as the regulator controls the amount of voltage, regulator problems overcharging, rectifier problems not charging, and discharging as the rectifier only alows current to travel in 1 direction, when it fails the battery voltage can then travel past it causing a discharging state
Top Electrical Supplies Experts
john h
Robert Wooley
Robert Wooley
Are you an Electrical Supply Expert? Answer questions, earn points and help others
