Tip & How-To about Seiko Kinetic watch
Necessary placement position of Seiko Kinetic Capacitor
This is one of several photographs taken with Macro detail to help anyone wanting to install a capacitor in a Seiko Kinetic watch.
When I first started there was very little guidance, save for some hasty videos that assumed too much prior knowledge, or photos that made little sense.
So, with the basics:
1) The all important peg.
The Mylar Insulator has a hole which slips over this peg...
doing that initially and correctly will save you frustration galore.
I will post another photo later about the orientation of the Mylar Insulator, as it absolutely must be, so that it does cover what it needs to cover, and yet does not block transmission of a charge where it shouldn't.
A tricky little piece of dexterity that caused some cursing occasionally.
2) A specific little square notch that is only for the Left Hand contact of the Capacitor.
If you start with the Capacitor "upside down" (with the shiny side face down" unlike other watch batteries, and slide it tipped downwards initially, as shown in the photo, then it will slip under the little lip that is has to hide under, which is at 12 o'clock in the photo
3) This is a little detail most videos never mention: There is a tiny foot
on the end of the Right Contact.
That foot absolutely must be in contact with the tiny piece of materiel as shown in the photo.
If it is not, the capacitor won't work.
4) A piece that touches one of the coils, as it is supposed to.
Caveats: 1) Do not use metal tweezers
2) Do not Short the Bridge Plate and the foot's resting materiel area
3) There is a gold toned metal spring retainer...be certain the Capacitor is fully inside that spring, and not merely laying on top of it.
(I like to envision the foot as the bottom of the number "9", and in that manner
the gold toned spring is at the top of the "9")
Seiko Kinetic watch Logo
my watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
My Kinetic watch stopped working.
I highly suspect and probably you also suspect that the energy storage capacitor needs to be replaced. My experience in working on these is that they are only good for about 3-4 years. I only replace with a new Seiko Lithum Ion battery. Check www.timelywatchrepair.com
Aug 02, 2006 | Seiko SKA192 Wrist Watch
385 people viewed this tip
Top Seiko Watches Experts
Marvin
Marvin
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
