You can print the document from anywhere using your smartphone or tablets.The technology that 123 HP Envy 5661 printer uses for copying your documents by using digital image processing technique. 123 hp envy5661 printer setup is essential to print, scan or copy your documents. To install and Setup your HP Envy 5661 printer, you can use our upcoming steps.
Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later. STEP 1 : BEFORE INSTALLATION
If you want to connect the printer 123 HP Envy 5660 Setup to your wireless network, make sure you know the network name and password.
Connect your Windows computer to the wireless network and make sure the HP printer is compatible with the wireless
Obtain the network name (SSID) and network passphrase (WEP key or WPA). A broadband internet access is must be used. Make sure you have the USB cable provided along with the printer package.
Turn on your printer, router, and computer and make sure the computer is connected to the same wireless network you want the printer to connect to.
If you have connected any USB cable to the printer, disconnect it before you proceed with the software installation.
Follow the instructions to remove the USB installation if it was previously setup on your computer before you continue:
Search for the HP folder in the list of installed software programs, click the HP printer folder, and then click 123.hp.com/envy5660
Once the HP Printer Assistant software opens, click Utilities -> 123.hp.com/setup 5660 & Software Selection.
Continue to follow the prompts and click Convert a USB connected printer to wireless or Connect a new printer.
To complete the software installation, follow the on-screen instructions.
You can also run HP Print and Scan Doctor, an automated tool to connect the printer to your wireless network.
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
If the printer is not turned on, press the Power button to turn it on.
On printer's control panel, touch the Wireless icon to preview the Wireless Summary screen.
On the Wireless Summary screen, touch the Settings icon and then touch Wireless Settings.
Under the Wireless Settings menu from 123.hp.com/setup 5660, select Wireless Setup Wizard and follow the on-screen instructions to complete the setup.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
Turn on your HP printer and eject any USB cable if connected to the printer.
Go to our website and navigate to the download page where you have to download the printer software manually.
Select your printer model when prompted and then, follow the on-screen instructions to reach the download page.
Next, to the full feature, click Download or click Basic Drivers.
To help you troubleshoot the scanning issue with HP Envy All-In-One printer, it is recommended to download and install 'HP Print and Scan Doctor' which will automatically diagnose the issue and try to resolve it. To download the tool, please find the link given below and follow the instructions given under 'How do I use the Fix Scanning feature?' topic: http://support.hp.com/us-en/product/HP-ENVY-4500-e-All-in-One-Printer-series/5304875/document/c03286146/
These steps are for HP Connected. Go to HP Connected, and then log in to your account. Click Services. Click Printables, if it is not already selected. Click the minus symbol ( ) to the right of HP Printables - Useful content delivered to your printer to see the Printables available on your printer.
Press the Down Arrow ( ) to select the printable that you want to stop or pause, and then press OK. Press OK again. The printable's Settings menu opens. Press the Down Arrow ( ) to select Turn off Scheduled Printing or a Pause option, and then press OK.
