Tip & How-To about Sharp LC-60LE600U 60" LCD LED TV 1080P
You may get a vertical black line appeared on your LD screen. Don't panic. You may not have to replace the LCD panel (cost $1K more) or replace the TV. This is likely due to the issue with X-Y control board (either with connector or electronics). Here is the trick, use your hand to apply pressure on the TV frame (the edge if there is one, not directly on the LCD itself) exactly above or below where the line is. I was able to make the line disappeared in a few trials. I have done this 2 to 3 times in the last 3 years. I guess the same may apply to a horizonal black line and you press on the left and the right of where the line is. Good luck and let us know if it works for you.
This tip may work on 1 line of defect. If you have more lines as group or they appear in several areas, you will have a real problem that needs serious repair.
