Tip & How-To about Panasonic Lumix Cameras
If you have a older Lumix that does not want to power on
As you know Panasonic issues Firmware Updates that can be downloaded online, and then installed using a computer and an SD card.
Some of those Firmware Updates made the cameras refuse to turn on if the battery was not an "approved" Panasonic battery.
This significant change was not publicly announced.
Panasonic Lumix batteries are available, but there are also dozens of different generic Lumix batteries available, and there is no reference source as to which generic batteries are "approved."
Therefore I would encourage you if you have a Lumix camera that is balking on startup to first try a genuine Panasonic Lumix battery that is fully charged.
You may find that the only problem was a generic battery that the camera did not care for.
(And of course many "Lumix" batteries sold online are not actually Lumix batteries, but merely counterfeits. They have Lumix markings and are often very good
imitations on visual inspection.)
Another reason some Lumix cameras will not power up is the memory card.
Sometimes people use a newer SDHC type card in an older Lumix, and the camera goes into electronic spasms trying to read the newer card. An older plain vanilla SD card will often solve the problem instantly.
If a Lumix camera is not powering up with a 8gb SDHC card there is a good chance it will power up immediately with a 1gb SD card.
I frequently recommend the Lumix TZ5 to people starting out, as it is a quality build, metal, not toy-like plastic, has more manual controls than most people will ever use, and the engineering is remarkable. I repair TZ cameras and donate them to homeless shelters and domestic abuse safe houses and college photography students and such, as they have full User Manuals available to download, full Service Manuals available for download in PDF format, have a very gentle learning curve, and produce photographs that are superior to many of the current cameras in the 600 to 800 dollar range. Yet a used TZ5 can be bought for 50 dollars or so.
Update the Firmware to v 1.2, never carry it in a leather camera case or pocket or purse or with any cloth of any kind, and you have a superb camera for many years.
Cameras Logo
micromax V8
If the SD card was used in something else there may be a format issue. You could try reformatting the card or buy a new card, personally I would buy a new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/andrew_d2df42288260d96e
May 30, 2014 | Audio Players & Recorders
How do I unlcok my Panasonic SDHC 8GB Photo Card so it will work on my Canon A620 Camera? The Card works fine on a FUJI camera.
The Canon A620 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. This is a hardware incompatibility that cannot be overcome by firmware updates or other means. You have to use MMC or SD cards, up to 2GB in size.
Feb 08, 2011 | Panasonic Cameras
power issues with panasonic tc32lx70
You need to go to Panasonic dot com search for TC-32LX70, go to software updates. Use a blank SD card and format it save the firmware file SDDL.SEC to it. Carefully open the "service panel" you may need to remove the entire back case? since it seems the frame is holding the service panel down. 1)power on the TV
2)insert the SDcard with firmware update into the rear(lx70) or the sdcard slot on the side(lx700)
3)follow the on-screen instructions.
4)when it's finished, remove the SD card.
turn off or unplug for 30+ seconds
then plug it back in.
5)power on.
6) perform the first time setup.
Mar 12, 2009 | Panasonic TC-32LX70 Television
Panasonic CN-NVD905U SD Card map update download
I bought the map update from Panasonic for $150, even tho it was advertised for $300. I called to order it, and it came with a disk and SD Card.
Mar 11, 2009 | Panasonic Strada CN-NVD905U GPS Receiver
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
