Tip & How-To about Washing Machines
Hello...
IE Error it means INLET ERROR.. Water is not coming or not filled in the particular given time by the program.. What u have to do is just close the inlet tap then remove the water hose from the machine.. Then u can see the inlet valve if u see inside of the valve u will find a small water filter take that filter slowly dont push the filter.. After removing u have to clean properly using old tooth brush after cleaning again fix everything and start the machine.
Thanks
Hi
Error
code IE on LG dishwasher means Inlet error. This error comes up when the Water
Supply Tap is closed or Water Supply is shut off. If water supply is turned on
then make sure that the Inlet Hose is not kinked and water Pressure is not low
(should be above 10 psi). Next thing to check for is Water Inlet Valve, measure
the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of
Inlet Valve is not clogged.
Hope this helps... Please post back
for further assistance.
Daniel
