Tip & How-To about Samsung Galaxy Tab 2 7.0
How to force Samsung Galaxy Tab to shutdown
1.There is no "force shutdown" as far as I know, but you can force a reboot by holding down the power button for about 15 seconds.
2.No force shutdown for galaxy tab, but you can use this trick.
  1. Plug the charger into your galaxy tab.
  2. Hold down power button for 10 seconds, and wait to reboot.
  3. After that, the screen will be change with charging battery.
  4. Plug off your tab, and it will be shutdown.
  5. For Tab S and Tab A
    Should work with 8.4 or 10.5
    6.Hold the Power button, Volume Down button, and Menu key for 10 seconds. You will enter download mode, simply press the volume down button to restart tablet.
    After reboot, you tablet should perform as normal
Samsung Galaxy Tab 2 7.0 Logo
how to reboot my samsung galaxy tab s2 tablet when it wont shut off
my galaxy tab e is stuck it will not shut down or restart
Have you tried forcing a hard restart? You need to press and hold the Volume down button AND the Power/Lock button together for up to 20 seconds. This should make the tablet think you disconnected the battery and force it to shutdown without power. Then you should be able to restart it again as usual.
I forgot my password to my Chromo Tablet & I need to know how to reset the password.
Check to see if there is a Reset button on your tablet. Usually it will be next to Power or Volume buttons. Use a small Pin to insert, press, and HOLD it for 15 seconds. Your tablet should reboot. See if it will reset your tablet and let you log into your tablet.
If that does not work, press and hold Power button until your tablet turns off completely. Press and hold Volume Down + Power at the same time for 15-20 seconds. See if the Recovery menu will comes up.
If still not working, power off again. Press and hold Volume Up + Power buttons for 15-20 seconds.
a video clip that was running will not stop, can not reboot or switch off iPad
push the home button twice to bring up all active apps; swipe them all one at a time to the top of the screen, or, hold both the home and power button down for 10 seconds to force a hard shutdown.
2answers
kindle fire screen repair
Press and hold the power button for fifteen seconds or so. Does it turn off then? If so, press and hold the power button for a second or two. Does it start to reboot then? Does it work properly now?
Top Samsung Tablets & eReaders Experts
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
