Tip & How-To about Samsung Televison & Video
How to Configure Smart DNS on Samsung Smart TV Find Your Public IP Address
If your TV is connected to internet, press the Menu button on your remote device and select the Network option. Select the Network Settings and then, select IP settings option. The existing IP address of your TV appears. It will be a private IP address if you are using router to connect to your ISP.
How do get the IP address for my Samsung smart Tv Google Search
Televison & Video Logo
Setting up internet on akai smart tv
How to connect
  1. hit the Menu button on your TV remote.
  2. choose the Network Settings option then Set up a wireless connection.
  3. select the wireless network name for your home Wi-Fi.
  4. type your Wi-Fi password using your remote's button.
connecting netflix
How do I set up my Panasonic TV?
Hit the Menu button on your Panasonic TV remote.
Select Network > Network Connection.
Select Wireless.
Select Wireless Network Settings.
Find your Shaw network name in the list of available networks and select it.
Enter your network password.
Your wireless connection should now be set up.
On these devices, the Netflix App can be accessed via VIERA Connect or the Netflix button on your remote control. If your Panasonic Smart Device does not have the Netflix App, it can be downloaded onto any internet connected external device (smartphone, tablet, gaming console).
What type of device do you have to connect to Netflix?
If watching in browser on desktop you need to install Silverlight
https://help.netflix.com/en/node/23742
How do I get the IP address for my Samsung smart Tv. I dont have a instruction manual
hi Deanna.
this is all i could find out from the internet.
If your TV is connected to internet, press the Menu button on your remote device and select the Network option. Select the Network Settings and then, select IP settings option. The existing IP address of your TV appears. It will be a private IP address if you are using router to connect to your ISP..
or go to this link and see if it helps you out.
how to get internet in our nintendo
Their our 2 options to connect your Wii to the internet.
The first option is wireless.
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
      (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Select "OK," "Save Settings," and then "Yes."
The second option is wired internet. For this you must purchase the Wii wired LAN adapter.
how to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
