Tip & How-To about Computers & Internet
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
Computers & Internet Logo
What are the new features of macOS Sierra?
There's a lot going on in macOS Sierra
Siri, Universal Clipboard, Auto Unlock with Apple Watch-these are just three of the features that Apple showcases for macOS Sierra, the latest version of the company's Macintosh operating system that made its debut last Tuesday. We go over the marquee features in our review, but there are a few features that go unheralded. We'll shine a little bit of the spotlight on them in this slideshow. These are less glamourous, but they make your Mac a lot easier to use. Messages: Per-conversation read receipts
Instead of having Messages send a read receipt for every conversation, you can do it on a per conversation basis. During a chat session, click on the Details link at the top right of the window. You'll see information on your chat partner, and below you will find a checkbox for "Send Read Receipts." Check the box to activate.
Apple Mail: Quick filter
In your Apple Mail inbox, you'll see a new icon of a circle with an upside-down triangle of lines. Click on it and "Filtered by" will appear it will filter your email based on what the blue text says. Click on the blue text to adjust the filter. Coordinated alerts
So you're sitting at your Mac, with your iPhone in your pocket and your iPad docked to your Mac, and you get a text message. In the past, you'd get a cacophony of alerts, one from each device. Now, with Sierra and iOS 10, the alert appears only on the device you're using
Notes: Collaboration
The Notes app in Sierra has a new feature where you can invite others to edit and write in a note. Next to the Share button on the upper right is a button you can click to "Add people to this note." Invites are sent via Mail Messages, Facebook, Twitter, and other methods. Time Machine: SMB support
Time Machine now includes support for the Server Message Block (SMB) network protocol. That means better compatibility with third-party network-attached storage (NAS) devices.
Autocapitalization and period shortcut
In System Preferences > Keyboard > Text, you have two new options: "Capitalize words automatically," and "Add period with double-space
New dictionaries
Apple has updated its dictionaries. You can activate the new dictionaries in preferences of the the Dictionary app. The new dictionaries are:
• Traditional Chinese definition dictionary
• Danish definition dictionary
• Italian-English bilingual dictionary
• Dutch-English bilingual dictionar
Sep 25, 2016 | Apple macOS Sierra
stop sound alerts on the Razr phone
When are the sound alerts occuring? Do they correspond with notifications at top of the screen?
Mark
Motorola Support
Sep 16, 2014 | Motorola RAZR Cell Phones
forgot my password and now the screen is locked
1. Verify that you are using the latest version of iTunes before attempting to update.
2. Connect your device to your computer.
3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
4. Select the Summary tab.
5. Select the Restore option.
6. When prompted to back up your settings before restoring, select the Back Up
option (see in the image below). If you have just backed up the device, it is not
necessary to create another.
7. Select the Restore option when iTunes prompts you (as long as you've backed up,
you should not have to worry about restoring your iOS device).
8. When the restore process has completed, the device restarts and displays the Apple
logo while starting up:
After a restore, the iOS device displays the "Connect to iTunes" screen. For updating
to iOS 5 or later, follow the steps in the iOS Setup Assistant. For earlier versions of
iOS, keep your device connected until the "Connect to iTunes" screen goes away or
you see "iPhone is activated."
9. The final step is to restore device from previous backup
If you can not restore your device then you will need to go to recovery mode.
Placing your device into recovery mode:
Follow these steps to place your iOS device into recovery mode. If your iOS device is already in recovery mode, you can proceed immediately to step 6.
1. Disconnect the USB cable from the iPhone, iPad, or iPod touch, but leave the other end
of the cable connected to your computer's USB port.
2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the
red slider appears, then slide the slider. Wait for the device to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake
and Home buttons at the same time. When the device turns off, release the Sleep/Wake
and Home buttons.
3. While pressing and holding the Home button, reconnect the USB cable to the device.
The device should turn on. Note: If you see the screen pictured below, let the device
charge for at least ten minutes to ensure that the battery has some charge, and then
start with step 2 again.
4. Continue holding the Home button until you see the "Connect to iTunes" screen.
When this screen appears you can release the Home button.
5. If necessary, open iTunes. You should see the following "recovery mode" alert:
6. Use iTunes to restore the device.
Dec 26, 2013 | Apple iPod touch
Iphone task and calendar alerts disappear when I enter password
Depending on the OS you are running they are in Notification Center(iOS 6 and Later). You can access Notification Center by swiping down from the very top of your screen in iOS 7. You can change Notifications on an app by app basis in Settings, Notification Center.
Jun 03, 2013 | Apple iPhone Cell Phones
216 people viewed this tip
Ekse
Marvin
Marvin
