Tip & How-To about Android Apps
Are you looking for a way to transfer data from old Android phone to the new one? That's great! Here in this article, you'll learn two efficient methods to transfer data from Android to Android without any data loss.
Method 1. Transfer Files from Android to Android via Bluetooth
Smartphones typically have integrated Bluetooth hardware, and Bluetooth can be utilized to wirelessly transfer files between nearby devices. This seems like a solution that would work across all smartphone platforms. However, while Android supports Bluetooth file transfers, Apple's iPhone does not. The following tutorial will explain how to transfer data from Android to Android via Bluetooth.
Step 1. Turn on Bluetooth connectivity on both of your Android devices.
Step 2. Enable Discoverable Mode to scan nearby smartphone.
Step 3. Click the Available Equipment to complete the pairing request.
Step 4. Find the file to be sent and click Share to begin the process.
Note: Please take into account to turn off the Bluetooth as soon as finished.
Method 2. Transfer Data from Android to Android via Mobile Transfer
Gihosoft Mobile Transfer is the best Android to Android transfer solution that enables you to transfer contacts, messages, call logs, photos, music, videos and calendar from Android to Android. Moreover, it supports almost all Android devices like Samsung, Huawei, LG, HTC, Google, Motorola, Sony, ZTE and so forth. Check out the following steps to find out how to transfer data from Android to Android.
Step 1. Download, install and run the Mobile Phone Transfer on your PC and get into the Phone to Phone channel.
Step 2. Enable USB debugging on your Android phone and connect two phones to PC respectively via USB cables.
Step 3. Select files to transfer from Android to Android and tap Start Copy.
Note: Please click Allow if a pop-up window appears on your screen when you connect your Android phone to PC. Any questions, you might refer to how to connect Android phone to PC.
In conclusion
The above is the most effective way to transfer data from Android to Android. Which one do you prefer? As far as I'm concerned, I prefer to use the Gihosoft Mobile Phone Transfer. Except for transferring files from Android to Android, this phone transfer software can also allow you to transfer data from Android to iPhone.
