20 Most Recent Westinghouse MDB631 RF Dishwasher Questions & Answers
Hi - I dont do repairs for these mid range appliances - however I believe the problem is with the dirt caught in the jets and through the water reticulation.
Try - take the arms off top/bottom if applicable and run the machine and check your pressure from the pumps and have a nosy the if there ae any blockages of the jets as these will give the indications of the symptoms you have posted..
Good luck
Westinghouse... | Answered on Jun 22, 2011
Sounds like the seal has gone
Westinghouse... | Answered on Jan 02, 2010
you can check it with a ohm meter from end to end. If you have continuity (a reading) it is good if you get no reading the heater is bad.
Westinghouse... | Answered on Oct 10, 2009
ON the the control pannel it might show a symbol of a lock. You will need to hold that key or sometime Keys for 3 to 5 seconds to release the control lock.
Westinghouse... | Answered on May 24, 2020
Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes
?· Check heating element
?· Check thermostat
Westinghouse... | Answered on Jan 20, 2020
Heating element or thermal cutout
Model number may help in diagnosis
Westinghouse... | Answered on Jan 02, 2020
Look for silverware jammed against hinge.
Westinghouse... | Answered on Oct 31, 2018
read about it in the owner's manual... good guidance there.
Westinghouse... | Answered on Sep 14, 2018
I would 1st check your filter. Most dishwashers have them, and they get backed up. Usually on the bottom of the dishwasher. You can google location of yours specifically.
Westinghouse... | Answered on Jun 09, 2018
Gary Miller was closest. You can also try this:
After the outlet hose has drained, open the dishwasher door and blow hard into the outlet hose (try not to get any gunk in your mouth! I usually put my hand in between the hose and my mouth.
You will find a bit of resistance then it should clear. Remove the filter (the one you remove and clean after every wash) and see if there is any gunk in the sump. Remove what you can by drawing the water out as best you can and using a rag to remove the gunk. Close the door and see if it tries to fill. Let it fill for a while until there is some water in the sump. Do the blow through the outlet hose trick again to see if it has cleared.
If you ket the dishwasher drain via the outlet hose, any gunk in the hose will end up clogging it again.
Dishwashers Logo
Popular Tags
8 questions posted
Top Westinghouse Dishwashers Experts
Michael Thomas
Michael Thomas
Lawrence Oravetz
Marvin
Marvin
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Dishwashers
Most Popular Question
dishes not getting clean
  • Dishwashers
