20 Most Recent Westinghouse WST1550 Wired Deluxe Upright Vacuum Questions & Answers
you have to take the headlight lenses off with a small screwdriver. then a philips screwdriver to take the 2 screws out. one each side. then remove the foil shields on each headlight . then snap loose the rear plastic clips on the cover and it will come right off. it took me an hour to find out how and 10 minutes or less to take it off. watch for the micro switch on the circuit board being worn out.it will stop the roller brush from turning.its a dollar part at any good electronics store ,but will have to be soldiered in or service might have a few from the westinghouse line .so will a broken belt which is a special grooved belt available from fantom at 18007987395..
Westinghouse... | Answered on Jan 19, 2013
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Westinghouse... | Answered on Aug 10, 2010
Yes, the belt is probably too loose or broken...
replace the belt first before trying anything else..
heatman101
Westinghouse... | Answered on Aug 04, 2010
Check at your local appliance store
Westinghouse... | Answered on Jan 18, 2010
i need a new bin filter mine smells like mildew i washed it like it said and it now stinks.
Westinghouse... | Answered on Feb 27, 2009
The manufacturer or www.searspartsdirect.com with the COMPLETE model number.
Westinghouse... | Answered on May 16, 2012
Westinghouse WST1550 Wired Deluxe Upright Vacuum Logo
14 questions posted
Top Westinghouse Vacuums Experts
Marvin
Marvin
Are you a Westinghouse Vacuum Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Vacuums
Most Popular Question
open vacuum assembly
  • Vacuums
