20 Most Recent Learning Curve Toys Thomas the Tank Engine Track Rider Questions & Answers
I would check the battery voltage with a multimeter if possible. Battery should read at least 6 volts. Most likely the battery is too old to take a charge if it’s been sitting unused since 2006. I’d replace the battery first and then go from there.
Learning Curve... | Answered on Oct 09, 2017
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
Learning Curve... | Answered on May 03, 2013
Take the wheel base of the train in one hand. Point the' face straight up. Place your other hand on the top with you index finger on Thomas' face. Push down towards the ground with the hand on the top, and then pull apart. There is a little tab on the back that you need to get over. Some times the first time is the hardest.
Learning Curve... | Answered on Mar 18, 2013
just pull of the black coal top and it uses 1 c battery
Learning Curve... | Answered on Sep 05, 2011
4 hours
Learning Curve... | Answered on Oct 16, 2010
From Peg Perego's website:
What do I do if I have a problem with my product that I can't solve myself?
You can call our customer service department at 1-800-671-1701. Customer service hours are Monday - Friday 8am - 4:30pm Eastern time
(http://us.pegperego.com/toys-site/support/TPSEC002/)
Learning Curve... | Answered on Jul 24, 2010
re: istbruno
my daughter told me, to squeeze the sides of the train and pull up and there is where the battery goes.
i had the same problem.
hope this helps
Learning Curve... | Answered on Jul 21, 2010
well youlle realy need to buy the batteries that could fit and move into the toy you bought. also if the battery you used dindt work. maybe you should try a medium sized battery.
Learning Curve... | Answered on Apr 07, 2010
The batteries are low, when the music plays on a toy and the motors stop it usually means low batteries,
Learning Curve... | Answered on Jan 26, 2010
Hey. I was looking for the same thing and found this answer on yahoo answers:
"loosen the phillips-head screw on the underside front center of the jet engine train (you might not have noticed it - it is behind the coupling magnet assembly, which you can move to the side and also has an opening to access the screw) - once the screw is loosened, you can lift up the 'jet engine' from the base to access the battery enclosure"
http://answers.yahoo.com/question/index?qid=20071225073953AAHYJKb
Learning Curve... | Answered on Jan 14, 2010
Try searchig E-Bay I normally manage to find any type of battery I have needed. If not research it on GOOGLE you will be able to find lots of suppliers for batteries. I hope this helps.
Learning Curve... | Answered on Nov 05, 2009
Learning Curve Toys Thomas the Tank Engine Track Rider Logo
38 questions posted
Top Learning Curve Toys Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Learning Curve Toys Toy Expert? Answer questions, earn points and help others
View Most Popular
  • Learning Curve Toys Toys
Most Popular Question
peg perego battery
  • Toys
